Old 12-17-2008, 01:09 PM
Drye-123 is on a distinguished road
Thumbs down battery alm
I have a fanuc om control on my machineing center. The screen shows a BAT alarm on it. I have change the 3 d size batteries in it. 3 different brands and clean the contacts, and measure the voltage on the batteries themself and on the cable going to the board. They all measure good. Is there some where else to look? I also backup the parameters, but not anything else, the manual i have dose not tell about backing up the diagnois,etc.
Old 12-17-2008, 01:44 PM
Rich 72 is on a distinguished road
We have some newer lathes that have batteries on the back of the operator screen and the keyboard, if it is a fanuc check the servo amps also because they have batteries too. One other thing to check (don't laugh or get mad) did you install the batteries in the right direction? Only reason I ask is because I've done that in the past and didn't realize it until after I lost all the parameters
Old 12-17-2008, 02:23 PM
Yes i did 4 times not mad at the answer, you can turn the batteries around.
Where on the sevro would the battery be? The controls are 1992 model. What would the batteries look like , watch battery size, e-prom stlye, ect.
Old 12-17-2008, 06:58 PM
Jung is on a distinguished road
To punch out diagnostic: in edit mode + diag screen --> Output Start
In Fanuc O PMC data are registered in diagnostic so you have to backup if your machine have PMC data.
If your machine is using absolute encoder, there must be another 4 batteries case. Replace these batteries also.
Old 12-18-2008, 08:26 AM
On our machines the servo batteries on on the front of the servo amplifier, there should be a rectangular cover that will stick out and have 2 wires that plug into the front of the amplifier. The battery configuration could be 1 of several styles ranging from a single 3 or 6v (about the size of a AA battery) to a pack of 4 that are shrink wrapped together. If all else fails call fanuc, I've had a fair amount of luck with them over the phone
Battery balancing CamEllis General Electronics Discussion 7 12-04-2007 01:50 AM
CPU dead battery LT1TRUCK Computers and Networking 2 09-10-2007 06:47 AM
Battery Replacement lovell110 Haas Mills 13 08-10-2007 12:20 PM
Upc Battery & Zero Return Jedi General CNC (Mill and Lathe) Control Software (NC) 1 02-20-2007 08:44 AM
Battery Power!! JavaDog General Electronics Discussion 4 06-16-2005 03:20 PM
