Old 12-14-2008, 08:36 AM
Stebedeff is on a distinguished road
Fanuc 18 German to English
Is it possible to change the language to English on this model?
Kind regards...
Old 12-14-2008, 09:29 AM
dcoupar's Avatar
Looks like parameter 3102. German is 00000010, English is all 0's
Name:	F18 Language Parameter.jpg‎
Old 12-15-2008, 04:24 AM
Thanks dcoupar,
I checked the parameter 3102 and there all off. It's all English except the alarms. There all German. Would you by any chance have a parameter file of the Fanuc 18T?
Old 12-15-2008, 04:52 AM
f-bu is on a distinguished road
If you mean machine alarms, then this comes from PLC side. Check MTB keep relay description - there may exist a bit for language of the alarms.
Old 12-15-2008, 05:25 AM
viorel26's Avatar
viorel26 is on a distinguished road
Ladder message modify
If you mean alarms like "2030 Door open"( 2030 Tur Offen) You need to modify the message from ladder.
Old 12-15-2008, 01:40 PM
CHAD LAWSON is on a distinguished road
The messages can be changed often with just setting keep relays. if you have alist of them i would check them. if not there is a 9000 series par.
Old 05-24-2009, 03:26 AM
SuLeman Fanuc is on a distinguished road
System Alarm 970 NMI occured in PMCLSI , Fanuc series 18i
How r u?
I m Suleman Khosa and we have almost 50 CNC machines of Japan,Germany & Taiwan in which FANUC control was installed. I have one machine in which one problem was occured during start in early in the morning.after two to three start the machine then alarm is reset automatically and all day machine is working smoothly through out day. Then one more time occur early in the morning and reset after On/Off machine 2 to 3 times. Detail of alarm is given below.
System Alarm: 970 NMI occured in PMC LSI.
Manual of FANUC said: Replace the motherboard.
Fanuc series is 18i.
Fanuc Motherboard number is A02B-0283-B500.
Fanuc Master PCB number is A20B-8100-0661 .
That alarm is occur due to battery low because that machine is off for three years and not any power given to that machine. When we ON it after three years then its have no data. We changed its alkaline batteries and also lithium battery of motherboard and put all CNC SRAM data and CNC parameters after that machine is working properly only one week. Then its parameters are remove in one morning, we load all things and now its working properly but at morning its gave system alarm 970 and then working properly after two to three times ON. I have some wuastions from you. Please answer me.
Q1) Is it problem of backup battery?
Q2) Please give me the method of memory all clear function of FANUC.
Please reply me, because its too costly to replace motherboard.
Hope you will give me positive response.
My personal Email id is subhani_engr1@yahoo.com, please reply me at yahoo adress.
Thanks alot.
Old 07-03-2009, 03:37 AM
Osmanselim is on a distinguished road
hi suleyman
İf stil 970 NMI problem You can try change 24V Power suply modul
I think so Your I/O unit a little time Without 24 Volt and Machine give me alarm
Only Idea
Old 07-03-2009, 05:37 AM
namrataicem is on a distinguished road
yes i too want to knw this
dished-ends
www.dished-ends.com | www.icemcladplate.com | www.louver.in | www.icemgroup.com
Old 07-03-2009, 06:49 AM
cncmts is on a distinguished road
970 Alarm
Fanuc CNC Control Models Applicable:
16/18/21, 16i/18i/21i, 160i/180i/210i, ,
Machine Alarm Error & Message:
970 - NMI OCCURRED IN PMP
Alarm Description: RAM parity error or NMI occurred in the PMC-RB module. The main CPU board is faulty.
I also seen this alarm because the parameters wasn't in the machine in the right order.
Can't read German print chippah Mazak, Mitsubishi, Mazatrol 2 11-20-2008 04:55 AM
German drive maker justCNCit General Electronics Discussion 2 12-15-2007 04:32 PM
German certificate? Alarm Hero Employment Opportunity 3 09-10-2006 07:44 PM
interconvert from Japan to English Fanuc 3T hien100881 G-Code Programing 0 06-21-2006 09:05 AM
how do i change pcnc software to english from german chris69randy DIY-CNC Router Table Machines 1 05-24-2005 02:35 PM
