i am trying to drip feed from a pc to a fanuc om... i actually have a post from before but it was never fixed. think my best approach is to start over fresh. that said i have bought an in line tester so i can tell if the pc and controller are communicating. i am getting an 087 alarm. what is the first thing i should check... and does anyone know what lights on my inline tester would light up if the controller was telling the pc to stop sending. i know my controller will drip feed because i have done it before... i have messed with the baud rate... i have slide the fifo buffer down on the pc.. i am almost positive it is a situation where the pc is ignoring the controller or the controller isnt telling the pc to stop... |
I will assume you are asking which wires are jumpered together on the 25 pin side... 4 to 5 6 to 8 and 20 right now the machine is sitting with a rs232 in line tester... what would i look for if the machine is telling the pc to stop sending.. the tester has the following lights: RTS, CTS, DSR,DRT,CD,TD,RD |
i am checking now but i know we have drip fed with this setup before...and the cables were made by a fanuc tech... |
| k...what i have is wires 2 ,3,and 5 going out and the rest in a shorted together in a bundle.. I have no way of knowing what wires are what as they originate from the jack end and not the end that connects to the computer.. |
#11
| If i try to output a program..following the manual 1 computer to recieve 2.edit mode 3.program key 4.enter program number 5.out start the following happens with my inline tester 1. all lights red at the start 2. output start pushed all lights go green except for TD and RD.. 3. when output start stops flashing all lights return to red but i get nothing on the computer end.. |
#12
| Are you using XON/XOFF handshaking for your drip feeding? I went round and round trying get drip feeding to my 10M based mill working. I was trying to use hardware handshaking, thinking that it was superior to XON/OFF, but it turns out that at least the 10M only uses XON/XOFF for incoming files (drip feeding), and hardware handshaking for outgoing (punch) files. Once I enabled XON/XOFF flow control on my DNC software, all of my buffer overflow issues went away. - Cameron |
| Need Help!- Drip Feed | kirby | Fanuc | 23 | 10-20-2008 09:21 AM |
| Drip feed? | kotten1 | Mazak, Mitsubishi, Mazatrol | 5 | 07-08-2008 02:44 AM |
| Drip feed? | MrWild | Dolphin CADCAM | 1 | 02-24-2008 10:33 PM |
| BMC-20 w/Max II drip feed...... | GPena | HURCO | 6 | 10-31-2007 12:37 PM |
| Drip Feed | camtd | Surfcam | 0 | 07-31-2006 06:09 PM |
