I am stuck. I'm working with a new horizontal with a 31i control. I am writing a program and need to look at the tool in the waiting station. I'm wondering if anyone knows if there is a # variable related to the next tool. I know #4120 is the last T code specified, but that is not necessarily the tool in the set up station. Any help would be greatly appreciated! |
| This a lot of times is determined by the MTB. I would check the documentation from them to see if they built a system variable for the tool that is currently in the wait arm. If no documentation shows this there is a few ways you can approach this. I usually write the current tool and the tool at wait into the common variables. If you do a tool call and the machine does not put the tool back in the magazine once it finishes changing tools you could program the variables to keep track of this with a few lines in your tool change macro. If your machine does not use a tool change macro and runs from ladder you can set one up so it calls with the M6 code. Set variable #519 equal to the tool in the spindle and #520 to the tool in the wait arm. You can use any parameters that you want but make sure you use above #500 so they don’t clear at power down. M6T6 O9020(tool change macro) #20=#4120 … … M6 #520=#519 #519=#20 M99 There is a chance that the MTB set up a system variable that is the tool in the wait arm. I like to run this short program to see what all the system variables are used for if I don’t have a list. I have had machines with the current tool being used with your input output variables. Your input signals are parameters 1000-1035 and your output signals are 1100-1135 (thats what they are on my controls, not sure about the 31i). Put a tool in the wait arm then run this program. See if any of the variables matches the tool in the wait arm. If so then put a different tool in the wait arm and run the same program. If the variables match then you can be sure that the system variable is for the wait tool. O0004 #1=0 #2=0 WHILE[#1LT35]DO1 #[100+#2]=#[1000+#2]--(#100-#135 will be equal to #1000-#1035 in seq. )order #[136+#2]=#[1100+#2]--(#136-#171 will be equal to #1100-#1135 in seq. )order #1=#1+1 #2=#2+1 END1 M30 Stevo |
| custom Macro B options | gup | Fanuc | 2 | 03-09-2009 11:41 AM |
| Custom macro!!!! | chrisryn | G-Code Programing | 4 | 05-27-2008 10:13 PM |
| Custom Macro B On A 18t. | JIMMYZ | Fanuc | 3 | 10-18-2006 10:08 PM |
| custom macro | The Metal | Daewoo/Doosan | 2 | 09-28-2006 07:26 AM |
