I am trying to use a G68 rotational coordinate system on a VM5 OKK mill with a Fanuc 180i control. I am storing the angle in variable #550, and calling it with a "G68X0.0Y0.0R#550" line. It works great when using offset G54, but when I try to use any other offset (G55, G56, etc.) it wants to refer back to offset G54. I have tried moving the placement of the line all over in the code (before and after the offset callout), and nothing seems to fix it. Is this a parameter issue, or what have I got going on? And help would be greatly appreciated!! |
| Maybe try to specify the G55 before and after the G68 line. I would not think that this is a parameter issue but I could be wrong. My first guess on why the G54 works ok is becasue this is usually your default work coordinate. I would probably look at were you are making G55 modal and were G68 is going modal. I am pretty sure that I have used G68 with different work coordinates before and never had any problems. It was a long time ago but I will see if I can track down one of my programs and take a look at the sequence of code to see how I put it. Stevo |
| Fanuc OM B axis rotation | Kev4966 | Fanuc | 5 | 10-16-2008 02:09 AM |
| rotation | marcT | G-Code Programing | 4 | 01-30-2008 12:12 AM |
| 180i-TB and 18i-TB | mr_electrician | Fanuc | 2 | 01-22-2008 09:41 PM |
| G&L rotation | abigg | G-Code Programing | 0 | 10-02-2007 07:26 AM |
| rotation control | Art Ransom | Mechanical Calculations/Engineering Design | 1 | 09-18-2006 04:20 PM |
