Old 11-22-2008, 12:57 PM
trangt143 is on a distinguished road
fanuc 16/18ta
I'm new, i run on springfield grinder cnc.
On edit mode, i can open some of progs, but other can't ex O9000 up, do they have protection or hiding, if i open them, is it ok ????. Which dnc software xp for send/receiver progs, thank you
Old 11-23-2008, 11:30 PM
dcoupar's Avatar
Program numbers 8000-8999 and 9000-9999 can be protected.
Check parameter #3201 bit 0 (NE8) and bit 4 (NE9). If they are 1, then the programs with those numbers are protected. Also check bit 6 (PSR). If it's 0, then then searching for a protected program is disabled.
I recommend Predator DNC, available from www.predator-software.com
Old 11-26-2008, 05:38 AM
if it's 1, how i change it to 0, how i turn on and write parameter, does it affects everything if i change to 0, thank you. I have new laptop with usb rs232 9- pins, how i connect to fanuc 25-pins, if i use predator dnc, how i modify settings, to get progs from fanuc, i have to use punch rite ? Thank
Old 11-26-2008, 08:05 AM
stevo1 is on a distinguished road
You have to change to parameter write enable. This screen is the second screen off your offset hard key. It should be the first line at the top that says
Parameter write enable=1(on, off)
You must set this so you can change your parameters. You will get a parameter write enable alarm telling you that your parameters now can be changed. Now you can go to the Service area were your parameters are. If you type 3201 and press NO.search it will take you to parameter 3201. You can now hightlight bit 0 and change it and then highlight bit 4 and change it. Bits run from right to left 0-7 (76543210). This is to unlock your 8000 and 9000 programs. There is nothing wrong with unlocking these to change them if needed as long as you know what you are doing and have the orginals backedup. This lock function is typically because a lot of the important macros like tool change, auto tool offset, main machining, ect are there and you don't want anyone making changes to those. It also blocks these programs from being accidently deleted. You can change bit 6 to allowing searching and viewing of these programs once they are locked.
Make sure you go back and deactivate parameter write enable. All of the above must be done in MDI mode.
Your best bet is to go through and backup everything. Parameters, programs, offsets, PMC ect. You also have to keep in mind when doing program backups that if you have the 8000 and 9000 programs locked they will not punch out of the control when doing a backup.
Stevo
Old 12-02-2008, 02:58 AM
my laptop has usb-9pins, how i connect my fanuc which has 25pins, how i modify the settings of fanuc and predator dnc or any dnc ? Please help , thank alot
Old 12-02-2008, 07:32 AM
I have attached the settings for the 18M. These should be the same as the 18t.
I use Dostek for my DNC. They are pretty cheap and good service.
Dostek Incorporated
238 Westheights Drive
Kitchener, Ontario
Canada N2N 1j9
Tel (519) 742-5721
Fax (519) 741-8669
www.dostek.com
Ask for Doug Struthers
Stevo
Old 12-03-2008, 04:00 AM
how i make a wire 9 pins to 25 pins?, in diagram what is black and blue lines, can you give clearly information, so i will go to radio shark buy it, thank you alot
My old laptop has 25 pins lpt printer port, can i use it ? settings ? Please thank you
Old 12-03-2008, 07:39 AM
Here is the pin out that I use. I use the RJ45 jacks which are at radio shack. Just plug the labeled color in the proper outlit. I run LAN line between. You can not use the printer port for communication.
Stevo
Old 12-03-2008, 03:17 PM
My friend gave me CNC Minifile™ Part Program Loader (Greco Box), when I connect it to fanuc 16/18, then i punch out, it appeared messeage COM ERROR.....
How I setting on the fanuc ? thank you
Greco box's pix is http://www.grecosystems.com/products/minifile.html
Old 12-03-2008, 10:36 PM
BKCOM is on a distinguished road
Hi Tranpt143.
If you stay in Vietnam.
Please call or email to me. I will help you.
pvhung@v-se.com.vn.
mobile: 0989316703
  #11   Ban this user!
Old 12-04-2008, 01:17 AM
I'm in Cali, plz give me information
  #12   Ban this user!
Old 12-04-2008, 07:25 AM
Press your offset/settings key. This brings you to the screen with the Parameter write enable and I/O ect. You have to change your I/O channel. This is telling the machine which input output channel to use.
Stevo
GE Fanuc & FANUC proprietary posts CNCadmin Fanuc 44 01-05-2012 08:54 AM
FANUC & GE FANUC Repairs RRL Product Announcements & Manufacturer News 1 04-17-2011 11:50 AM
Need Help!- GeFanuc 16/18TA trangt143 General CNC (Mill and Lathe) Control Software (NC) 1 11-23-2008 11:26 PM
Lathe Dainichi F35 Fanuc 18TA - change diameter on radius jutek Fanuc 1 02-21-2007 03:57 PM
