Old 11-19-2008, 11:21 PM
unisys1 is on a distinguished road
Thumbs down Servo alarm 417
I have cortini T120 /cm italy make. I m getting servo alarm 417/427 Nth axis servo dgtl param . how i can solve this problem can anybody solve this problem..pls contact on+919825323285
Old 11-22-2008, 11:28 PM
MaCroB's Avatar
MaCroB is on a distinguished road
Not familiar with the control, but...
I'm not really familiar with the controller, however, most controllers follow similar PLC's for alarms. The alarm you are specifying seems familiar with a Fanuc Servo alarm that we had on one of our machines...It was a broken servo cable wire that caused the alarm. I would investigate continuity on your Nth axis (X, Y or Z, whichever one is alarming on you) and make sure there isn't a broken wire...
From there, work backwards towards the motor itself. You'll find that troubleshooting problems like this can be quite difficult, but if you start at the end and work backwards, you'll save yourself some time along the way....Money too! Cable is cheaper than a motor!
Good luck!
Old 11-23-2008, 09:38 AM
Al_The_Man's Avatar
I agree it sounds like Fanuc alarms.
see PDF
Old 11-25-2008, 10:46 AM
Al_The Man
Thanks for u r support. But from where i can get those parameter cos it seems becuase of battery cos it was dead.. pls guide me
Old 11-25-2008, 12:36 PM
Al_The_Man's Avatar
If this is in fact a Fanuc, what is the model? 0,10,15 etc?
NEED HEELP ALARM #414 Y AXIS SERVO ALARM? PICMAN Fanuc 6 04-29-2011 05:20 PM
Need Help!- Servo Alarm 401 nitrosnfr Fanuc 5 08-01-2008 04:24 PM
Need Help!- help me 400 servo alarm club35bucuk Machine Problems, Solutions , Wireless DNC, serial port 0 07-16-2008 12:33 PM
S03 Servo Alarm atscnc Daewoo/Doosan 0 05-28-2008 07:07 PM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
