Old 11-18-2008, 05:45 AM
cordillera1 is on a distinguished road
Unhappy G02 G03 Codes
Iam at school, this is my home work, but I am stuck with this. Please help mi o reidirect mi to a rigth forum. Thank you.
G0 X51. Z72. (STARTING POINT)
G1 X40.
G3 X21.34 Z81.4 I0. K15.
G2 X6. Z83.72 I10.67 K22.6
the test program (VDS) came with "end point not in circle" in G03 AND G02
I"ll be using a Okuma machine (Lathe)
Thank for any help
Old 11-18-2008, 09:24 AM
Derek.C is on a distinguished road
My guess is that you have your G2 and G3 backwards judging by your numbers .
Old 11-19-2008, 12:13 PM
phx phx is offline
phx is on a distinguished road
G1 X40.
Thank for any help
do you have a G01 or G00 in the next line after the G02?
Old 11-20-2008, 07:13 AM
sinha_nsit is on a distinguished road
Check your drawing. The centre of the circle must lie on the perpendicular bisector of the line joining the current position of the tool and the end point of the arc. Use radius method. You will always get an arc unless the radius is smaller than half the distance between the start and end points of the arc.
Old 11-21-2008, 09:26 AM
samu's Avatar
samu is on a distinguished road
Effectivly end point is not in circle defined by your number. G03 X ( x end point coordinate) Z(z end point coordinate) I(distance in X from start point to center) K(distance in Z from start point to center)
Need Help!- M CODES AND G52 fenix728 G-Code Programing 2 11-17-2008 08:03 PM
M-codes and G-codes 4 Matsuura ES-1000V maximusek G-Code Programing 2 11-27-2007 06:41 AM
Need help with G codes soldier G-Code Programing 2 11-23-2007 11:38 AM
Not new to g-codes but looking for some help stang-man G-Code Programing 6 10-01-2007 12:38 PM
MDI Codes Anyone know about them? manyhobies Coding 5 08-03-2007 03:16 PM
