Old 11-12-2008, 03:10 AM
Stebedeff is on a distinguished road
DNC on Fanuc OM-D
Hello all,
I have my machine hooked up on pc. Sending , receiving and even DNC works.
But with DNC i noticed that Fanuc reads only one line at a time as the pc sends one line at a time. I thought with DNC the pc would just keep filling the Fanuc buffer and Fanuc would just delete the lines that were executed. So that Fanuc would have a buffer of several lines and would be operating smoothly. Now i can see that it takes just a little time to recieve a line of commands and that reflects on the workpiece. I know it's just a setting in DNC but don't know which to change.
Any help would be appreciated, Thanks
Old 11-12-2008, 05:18 AM
Camber is on a distinguished road
I have the same issue but also dont know how to fix the problem. I will keep an eye on this thread. Thanks for bringing it up.
Old 11-12-2008, 07:56 AM
dcoupar's Avatar
I believe you're looking for parameter #0390 bit 7 (NODC3).
Name:	0M-D DNC Buffer.jpg‎
Old 11-20-2008, 05:50 AM
atilaye's Avatar
atilaye is on a distinguished road
I am using fanuc om-d with dnc too and machine has vibration and slowdown on radius and curve movements. i am trying to solve the problem with dnc settings. but i couldnt solve it yet.
Old 11-20-2008, 06:48 AM
Stu_M3 is on a distinguished road
Vibration
The vibration and slowdown is most likely to be caused by your post processor generating lots of small moves to generate radii if your cam system can generate arc output use that instead for smoother results.
Stu.
Old 11-20-2008, 07:08 AM
atilaye's Avatar
First thank you for your reply, I bought the machine 6-7 years ago. At that time i didnt have this problem. But 2,5 years ago one of the boards burnt out and was replaced. i wasnt here that time. machines parameters was lost. until that time i am having problems like that. 4th axis was gone too but i solved it. all this time i didnt changed postprocessor etc. because of that i am searching for parameters.
Old 11-25-2008, 01:43 AM
Thanks dcoupar!
Old 11-26-2008, 02:08 AM
dcoupar's Avatar
You're quite welcome.
GE Fanuc & FANUC proprietary posts CNCadmin Fanuc 44 01-05-2012 08:54 AM
FANUC & GE FANUC Repairs RRL Product Announcements & Manufacturer News 1 04-17-2011 11:50 AM
Fanuc & GE Fanuc Repairs RRL Product Announcements & Manufacturer News 0 10-01-2008 12:42 PM
Need post UG NX post for Fanuc Robodrill with Fanuc Series 16i-MB shj066 Post Processor Files 2 07-12-2007 01:59 PM
