Old 11-10-2008, 06:43 AM
mmxmb is on a distinguished road
Help with Fanuc drill and tap center model T
Hi, I am having problem with the above mentioned machine. All axis are working fine but the ATC is not responding to the command. (M06). Thw machine has Fanuc 0M-A control.
Also any has a DI/DO list?
Mike
Old 11-10-2008, 07:59 AM
stevo1 is on a distinguished road
If your tool change is written into your ladder try taking the machine to Z0 now program T2M6. This should start the sequence of the M6 through the ladder and put tool 2 in the spindle. Your machine could have maybe used a macro tool change which would basically do the mahcine movements to the tool change positions and any other special shut offs and then have a M6 in it.
My guess is that your M6 is not responding because you are not in a the proper position to allow a tool change. This use to happen on one of our VMC's until I wrote a macro to take the machine to the proper position when a T#M6 is called.
Stevo
Brother TC-211 CNC Drill Tap Center chakrind General Metalwork Discussion 5 09-22-2008 03:47 PM
center drill diameter developpement on mazak nexus 640m mill Denis13 Mazak, Mitsubishi, Mazatrol 0 01-30-2008 08:56 PM
Center Drill Drill Depth bowersjack General Metalwork Discussion 4 01-28-2008 08:53 PM
fanuc drill mate / robo drill post for enroute? goodplastics Post Processor Files 0 07-19-2007 05:49 PM
Do I need to center drill? jderou General Metalwork Discussion 9 06-15-2005 09:33 AM
