Results 1 to 6 of 6
Thread: Atc counting problem on Kitamua mycenter 2
    Oct 2008
    india
    Arrow Atc counting problem on Kitamua mycenter 2
    Dear All
    Facing a poblem on Kitamura Mycenter 2.Following are the details .
    Machine Model -kitamua Mycenter
    Fanuc Controller- 11m
    Nature of Problem- Machine is equipped with 30 tool atc and mag is driven hydrolically,position of mag. is monitired by a 6 bit encoder ,presently tool counting is not proper(counts erratically),all encoders signals are confirmed and found okey,problem seems to be with the data table of pmc.
    pl help to resolve the matter
    Regards
    Shree
    Registered Mitsui Seiki's Avatar
    Feb 2007
    Is this a new machine to you or have you run it before?
    Stefan Vendin
    Oct 2008
    india
    Dear Mr Stefan Vendin
    Thanks fo the reply ,this is a old m/c we brought ,at present machine is runnig without atc.
    cncrepairs
    Feb 2007
    You should have an orange or yellow button halfway down the panel to the left.
    If you press that button you'll get a screen that shows you exactly what the next ATC step is and where the sub arm should be. Make sure everything matches.
    Stefan Vendin
    Feb 2007
    Is this what your panel looks like?
    Stefan Vendin
    Registered chuy's Avatar
    Aug 2005
    I'm going to assume that your tool changer is on the outside of the machine in a cage that is more of a belt that is driven by 2 large gear type wheels. if thats the case than it may be that the encoder is loose so it's moving more than it should, and this makes it skip tools or could be some plastic teeth on the encoder wheel broke. or the encoder is just bad. If it's loose than have one guy change tools while the other moves positions for the encoder to the proper setting and keep an eye on the control panel to ensure your at the proper tool. The encoder is real sensitive so it takes time to adjust it.
    Good Luck.
    1. Replies: 6
      Last Post: 05-27-2007, 10:50 PM
    2. 10T Parts Count counting tool changes?
      By RBrandes in forum Fanuc
      Last Post: 02-12-2006, 08:23 AM
    3. What's a good way to have a counting formula?
      By Darc in forum CamSoft Products
      Last Post: 11-02-2004, 11:27 PM
