Old 11-07-2008, 02:35 PM
SSMrob is on a distinguished road
Fanuc 3m tachogenerator/spindle problem
Spindle won't go over about 4k...
Load goes into red when I try over 4k, and it makes a jittering noise.
RPM meter seems to read wrong..
How do I check tachogenerator output into spindle motor controller ie what pin/signal at control board?
Also, could this be bad brushes? Bad pickup brushes for tachogenerator? foreign material/metal chips in motor? bad parameters in controller?
Thanks in advance!!!
Old 11-07-2008, 03:16 PM
Al_The_Man's Avatar
Last one I had with this problem turned out to be the Tach.
It seemed to be putting out voltage ok, but a replacement solved the problem.
It would not hurt to check the main brushes anyway.
The DC tach is right on the back end of the motor and outputs 20v/1k rpm.
Old 11-08-2008, 02:36 PM
cncdiag is on a distinguished road
To tell you the check pin for tach feedback it would help to know the part number of the drive.
Need Help!- Fanuc O-Tc AC Spindle Motor Drive Problem suleman_mani Fanuc 3 10-28-2008 08:28 PM
FANUC AC MAIN SPINDLE problem!! Cole84 Fanuc 11 11-21-2007 10:12 AM
Fanuc O-MC spindle problem rai Fanuc 6 08-04-2007 04:41 AM
Fanuc 0M Spindle Speed Problem inthezone Fanuc 6 08-01-2007 04:14 PM
Fanuc 0i-MC controller Spindle Problem PJ Engineering Fanuc 7 05-18-2007 10:01 AM
