Old 11-05-2008, 09:17 PM
gabedrummin is on a distinguished road
FANUC O CONTROL
My machine has a .A16B-1010-210/04b main pcb ...can someone please tell me what control this is a what i should do to get the rs232 working thanks to all thank you
Old 11-08-2008, 09:59 PM
cncatj is on a distinguished road
Hi gabedrummi :
i do understand you have a Fanuc O series control.
I start communication set up for same control , OT in a lathe that i work on.
First thing you need is to have your cable made you will need also the CNC communication Software.
Old 11-09-2008, 01:16 AM
dcoupar's Avatar
Do you have RS-232 communications with other machines?
Old 11-11-2008, 08:47 AM
I HAVE CABLE AND SOFTWARE....NEED TI KNOW WHAT MACHINE PARAMETERS TO CHANGE //THANKS
Old 11-11-2008, 10:07 AM
stevo1 is on a distinguished road
I have a few things on the O series control. 1 is O series 1 is OM series. I am not sure what you have for a control. This should get you going in the right direction.
If you can let me know exactly what model OM,OMC,OMD,OT,OTC I have some that are more specific to the model. They should all be about the same.
Stevo
Old 11-11-2008, 02:07 PM
I DONT KNOW WHAT CONTROL IT IS ....THIS IS WHY I POSTED THE MAIN BOARD PCB NUMBER MY PARAMETER LIST STARTS AT 0 THRU 490........THEN IT STARTS AT 1000 THRU..8400........I DONT HAVE A 0552 PAR UNLESS i NEED TO CHANGE SOMETHING TO GET O552
Old 11-11-2008, 02:16 PM
Al_The_Man's Avatar
Normally it is right above the CRT on the Left side.
That number looks more like a 10 system.
OK, I just found it, it is a 0.
Old 11-11-2008, 02:26 PM
I just assumed you knew what control it was based on the title of the thread "Fanuc O Control".
As AL said it should be at the top left part of the control screen. It should also be inside the machine cabniet on a sticker with the serial number. I attached a PDF that should show the commone places it is mounted.
I am not that firmilar with the O series control. You say you can't view parameter 552? Is there a "Service" and "Settings" softkey? Some parameters are listed in one and not the other. Could be looking in the wrong screen.
Stevo
File Type: pdf How to Find CNC Serial Number GFF-3653.pdf‎ (170.9 KB, 154 views)
Old 11-11-2008, 03:48 PM
I HAVE A SETTINGS SOFTKEY AND THERE IS A OPTION FOR INPUT DIVICE O-3....3= CASSETTE..i HAVE IT SET TO 2.....ON MY PARAMETERS I HAVE 340.....310...311... AND 312.......ON THE BACK OF THE MACHINE THERE IS A FANUC TAG THAT HAS THE SERIAL NUMBER.....AND FOR CONTROL IT SAYS......O...NOT ZERO...THE LETTER O........
Old 11-11-2008, 04:16 PM
Al_The_Man's Avatar
I never heard of an O, I looked up that part number it shows a 0 (zero).
Do you have a setting screen? that show PWE, TV On, ISO EIA , Port etc?
  #11   Ban this user!
Old 11-11-2008, 04:45 PM
Yes I have three settings pages I have tv check input device output device ..iso...eia....on one page ...on page two is the parameter write enable..one too write o for locked ..and a third page for offsets...
  #12   Ban this user!
Old 11-12-2008, 09:57 AM
One of the very helpful members asked for the serial number........The tag reads type A04B-0220-B058.......CONTROL....O.....date of mfg 11-86....I hope this helps to figure out who this animal is thanks to all the members.....
G13 on Fanuc 0i control davisboys Fanuc 4 09-01-2008 08:25 AM
Need Help!- fanuc control ezavarse General CNC (Mill and Lathe) Control Software (NC) 2 02-22-2008 06:31 AM
Fanuc T6 Control adamant G-Code Programing 5 12-19-2007 11:09 AM
FANUC OT control need dnc help mike10 Fanuc 5 10-17-2006 03:27 PM
Fanuc 18T control m_ghaff2000 Fanuc 1 09-26-2006 07:05 AM
