Results 1 to 5 of 5
Thread: Fanuc drill macro with variable depth and fixed retract point
    Mar 2007
    At our shop we have a lengthy program that especially causes issues on our gildemeister lathe as it lacks memory to keep using it and keep your programs stored. I assume as it was written with CAM, and it rapids to .02 clearance above last peck, drills to a certain depth every time, and rapids back to .1 out of the part, and repeats. It's a royal pain to have to edit the program to get the desired depth each time, and eats a ton of memory. I'm currently reading up on macros, but haven't yet discovered if it was possible to create a macro that could be called up like the regular cycle, but rather than retract .020 above then peck more, could one be written to do like the lengthy program does, but remain flexible enough to easily change the depths of the holes? Thanks.
    Registered dcoupar's Avatar
    Mar 2003
    Sounds like a plain old G83 cycle. You might try this in MDI just to see...
    G97 S500 M03
    G83 W-2.0 R0 Q1500 F0.008
    Registered padobranac's Avatar
    Mar 2006
    Croatia
    Quote Originally Posted by dcoupar View Post
    G97 S500 M03
    Maybe Z-2.0 instead of W-2.0
    BTW, macro could be called through M/G/T code as I know, you have parameters to set that.
    Attached Thumbnails Attached Thumbnails Fanuc drill macro with variable depth and fixed retract point-untitled.jpg
    Sorry for bad english
    Mar 2003
    Either W or Z should work. W is incremental Z.
    Dec 2003
    Here is also a drill macro that may come in handy.
    Attached Thumbnails Attached Thumbnails Fanuc drill macro with variable depth and fixed retract point-drill_peck_macro2.jpg   Fanuc drill macro with variable depth and fixed retract point-drill_peck_macro.jpg
    1. Center Drill Drill Depth
      By bowersjack in forum General Metalwork Discussion
      Last Post: 09-04-2012, 01:20 PM
    2. Removal of the drill press depth stop threaded rod
      By devinchi in forum Shopmaster/Shoptask
      Last Post: 03-14-2010, 10:10 AM
    3. Macro variable example I programmed today.
      By theemudracer in forum G-Code Programing
      Last Post: 03-07-2007, 09:50 PM
    4. Macro variable for current tool diam ?
      By Shizzlemah in forum Fadal
      Last Post: 10-30-2006, 09:47 AM
    5. Problem with drill depth
      By Alan S in forum Post Processors for MC
      Last Post: 11-03-2005, 03:23 AM
