Old 10-22-2008, 07:20 PM
gabedrummin is on a distinguished road
fanuc controls
Maybe some can answer a question ,,, fanuc made 6m .. om controls for all kinds of machines . Why is there a differane in the parameters that have to be changed for a machine to commacuate through rs232......On the wire edm machines with 6...6m...6mb you have to change 310...311.312....313....and 340..........340...sets the port your using and the 310...through 313 are your settings baude rate and so fourth.....I have a wire edm ...on the machine name plate it says its a O control....I have been told because of the main board number its a OM CONTROL .I would like to set the rs232...but am having problems...I know someone will say parameters are from machine tool builder ....Fanuc speced out and built these machines...Elox only put there name on it....I have a manual for a wire with a 6 control....But I need the information for a O.....OM CONTROL ....Please can someone help me....thank you very much
Old 10-22-2008, 07:53 PM
Al_The_Man's Avatar
See PDF
Old 10-22-2008, 08:18 PM
Thank you for your replay ........This is the problem I am talking about I dont have a par...127.5 to change ......I am very confused..........
Old 10-22-2008, 08:33 PM
Al_The_Man's Avatar
I think you are talking about G127.5 which is a register (PMC to CNC) for DNC control.
If you want DNC then this has to be set on in the ladder by an switch etc.
If you are not concerned with DNC, then this does not apply.
flash cards for fanuc controls rags Fanuc 9 10-09-2008 09:21 AM
tooling priority in fanuc controls inflateable Fanuc 2 05-02-2007 02:11 AM
Fanuc 11M controls reference zero liston336 Fanuc 2 04-06-2007 05:14 PM
Controls Chuck Pool General CNC (Mill and Lathe) Control Software (NC) 7 02-23-2006 11:49 AM
Fanuc 10m Panel controls not multiplexing the professor Fanuc 18 01-19-2006 10:23 PM
