Results 1 to 6 of 6
Thread: rs-232 pinout config
    Nov 2007
    Unhappy rs-232 pinout config
    I have a Fanuc machine that Iam trying to hook up to a data switch box the end at the machine has a db-25 connection and the one at the pc end had a db-9 now I need to change the db-9 to a db-25 because the back of the box has a db-25 female plug .So does anyone have the pinout config for this ? I also have a fadal machine and Iam hooking that machine up to this box as well can I use the same config for the fadal pinout?and if not what is the right pinout config for the Fadal ?
    Dec 2003
    The equivalent pins from 9 to 25 are:
    DB25->>-DB9
    2 3
    3 2
    4 7
    5 8
    6 6
    7 5
    8 1
    20 4
    What is the 'Data switch box'?
    Attached Thumbnails Attached Thumbnails rs-232 pinout config-fanuc-0m.pdf
    Nov 2007
    Thanks but I already have this pinout config I need the one to go from db-25 at the data box ( Belkin Components Data switch model F1B028-E ) to db-25 at the cnc side the box has a db-25 pin on the back of it , I do not know if thie config that I have will work for this box I looked in the fadal book because that is one of the machine I am trying to hook up but it was the wrong config I guess I picked the wrong one for my computer. As you can see have not messed with the commucation line before that is why I need some help
    Sep 2005
    The same cable from the Belkin box to the CNCs will work for the Fadal and the Fanuc.
    Cable from Belkin box to Fanuc:
    NOTE: The Fadal cables will have to be FEMALE on the CNC end, where the Fanuc needs a male end on the cable
    Fanuc side (male) Belkin side (male)
    2 --------------------- 3
    3 --------------------- 2
    4 --------------------- 5
    5 --------------------- 4
    7 --------------------- 7
    6 ----
    8 ---- <-- jumper these 3 together on CNC side
    20 ---
    The cable from the PC to the "input" plug on the Belkin box will be 9-pin to 25 pin. This cable can be purchase at any computer store. Look for a "MODEM" cable, or a "9-25 adapter" cable. Do not buy a "NUL MODEM" cable, since these have crossed connections. Some of pins shown below with an asterisk (*) are really not needed, so if you're making your own cable, you can leave these wires out.
    PC (9-pin female) Belkin box (25-pin male)
    1 -------------------- 8 *
    2 -------------------- 2
    3 -------------------- 3
    4 -------------------- 20
    5 -------------------- 7
    6 -------------------- 6 *
    7 -------------------- 4
    8 -------------------- 5
    9 -------------------- 22 *
    Feb 2010
    i have a tree 310 journeyman with a dynapath 10 controller. does anyone have a pinout for the 9 to 25 pin cable? i have seen several different posts with different pinouts.
    Apr 2007
    BRAZIL
    Help,
    Hi all,
    I'm trying to make a multi-purpose X-Y-translation table from an old Matsuura milling-machine. It has a Fanuc-11M controller.
    My goal is to change to a controller which I program with MACH3. To do so I only need the X and Y servo motors and drives. They are the following:
    servo-drives: (velocity control unit) A06B6047H303
    Does anyone have a schematic of the servo-drive (or PCB)?
    Or a pin-out of the CN1 (FANUC 11M) connector of the PCB?
    Any information that can help me is also appriciated.
    I'm hoping that a simple +/-10V signal is sufficient for driving the servo's (if only I knew which pins to use of the CN1 connector). All further IO (encoder/limit-switches) can directly go to the controller.
    Greetings,
    Jaques
    1. Haas video pinout?
      By drunkenwhippet in forum Haas Mills
      Last Post: 08-25-2008, 09:54 PM
    2. #23-305-DS8A Pinout
      By Richie800 in forum Hobbycnc (Products)
      Last Post: 11-15-2007, 03:11 PM
    3. DB9 pinout cabling
      By miguisu in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 05-23-2007, 07:21 AM
    4. pinout (for MACH software)???
      By judi in forum Mach Software (ArtSoft software)
      Last Post: 01-23-2007, 03:59 PM
    5. DB9 pinout diagram standard?
      By nervis1 in forum General Electronics Discussion
      Last Post: 12-21-2005, 12:52 PM
