Old 10-21-2008, 11:46 AM
JMECKES is on a distinguished road
FANUC 3TD SPINDLE NOT RUNNING
Need some assistance. We have an old Mori with a Fanuc 3T Model D control.
At power up the spindle would not come up to the speed we set for the morning warm-up. Tried running a program in both memory and MDI, still no luck. We get about 200 rpm max in either hi or low range and it runs up to that speed very slowly. Any suggestions on where to start the exploratory surgery? We checked all fuses, but no voltages as of yet on the board.
Old 10-21-2008, 05:56 PM
cncdiag is on a distinguished road
What is the part number on the spindle drive?
Old 10-22-2008, 08:21 AM
A20B-0009-053 and the I/O is A20B-0008-0630
Old 10-22-2008, 11:00 AM
rajesh_1355 is on a distinguished road
Is this a AC Spindle with pulse coder feedback.
Old 10-22-2008, 11:10 AM
Yes it is. And it started to work now. We're starting to think that after the electrics warmed up that thermal expansion may have provided contact in a broken line somewhere. We are now letting the machine cool back down to see if we can repeat the problem.
By the way, a call to Fanuc proved to be very frustrating. The tech told me that if there was no Fanuc alarm displayed, there was no Fanuc problem, and that it must be bad belts on the spindle. Nice response. My guess is that if there is any voltage at all coming in on these older controllers that the diagnostics would not set an alarm state. Funny that the control didn't alarm when the voltage wasn't reached compared to what was commanded.
Old 10-22-2008, 02:52 PM
Did you check the command voltage when the machine was malfunctioning?
If the command voltage is low you will not get an alarm the drive will just run slow.
It will also give an speed arrival signal back to the control.
Old 10-23-2008, 05:02 AM
Next time if it repeats, write me , I have also faced this type of problem earlier.
spindle keeps running Runner4404spd Mach Mill 0 04-30-2008 10:25 PM
Spindle at 30% when running 400rpms carbidecraters Fadal 20 10-27-2007 04:47 PM
149 alarm spindle running need help!!! duckslayer Haas Mills 2 07-25-2007 08:51 AM
Spindle not Running Simon Lee DIY-CNC Router Table Machines 1 02-09-2007 11:56 AM
Running a Fanuc spindle motor Fudd General Metal Working Machines 3 11-11-2006 09:21 AM
