Old 10-17-2008, 07:20 AM
padobranac's Avatar
padobranac is on a distinguished road
Spindle stop (M5) and coolant off (M9) by Reset button (0-MC)
There must be some parameter(s) for that, because same controll (0-MC) on two machines, on first one Reset button stops spindle and turns coolant off, and on the other machine, it doesn't.
I have parameter book but I can't find anything.
Sorry for bad english
Old 10-17-2008, 08:25 AM
samu's Avatar
samu is on a distinguished road
I'm not sure, but take a look at prm#45 bit 6
1:selects clear conditions using reset button
0:selects reset condition using the reset button
I have no detail about what are clear and reset conditions but if this parameter is not set at the same value on both control, maybe it is the cause of your problem.
p.s. My english is worst than your
Old 10-17-2008, 09:54 AM
padobranac's Avatar
On both machines 0045#6 = 1 (clear state)
Old 10-18-2008, 12:02 AM
dcoupar's Avatar
My guess is that's part of the ladder. There may be a Keep Relay that lets you select it.
Old 10-20-2008, 05:29 AM
Dan Fritz is on a distinguished road
dcoupar is right. The spindle and coolant outputs are controlled in the ladder, so it would not have a conventional parameter. Don't mess with #0045 bit 6. That will change how G-codes are reset, which you don't want to do.
Old 10-20-2008, 06:35 AM
padobranac's Avatar
I know what #0045 bit 6 is, actually I have changed it when the second machine came to me so it is now equal on both machines.
If it is defined in ladder, it could not be changed? Maybe there is some D adress (DGN) which keeps it on.
Old 10-21-2008, 12:26 AM
dcoupar's Avatar
Perhaps if you told us what make/model of machine it was, maybe someone here has one with a list of keep relays.
Old 10-21-2008, 02:12 AM
padobranac's Avatar
It is KIA KV25P from 1995.
But i doubt that any one here has experience with this machine
Old 10-21-2008, 12:02 PM
xavierdemoura is on a distinguished road
Padobranac,
Try change D109#5 to 1 to stop spindle rotating and coolant.
Daniel
Old 10-21-2008, 03:22 PM
padobranac's Avatar
Thanks, I'll try it when I came to machine.
  #11   Ban this user!
Old 10-24-2008, 10:11 AM
padobranac's Avatar
I am not able to change D109#5 even if I am on MDI and PWE=1 and key is on write.
I have found in ladder some R adress which is called "RESET M CODE" but i can not affect on execution of it.
E-Stop Button widgitmaster General Electronics Discussion 3 05-19-2008 02:41 PM
Changing screen size or a keyboard trigger for the reset button maxboostbusa Mach Software (ArtSoft software) 3 03-16-2008 01:54 PM
automating the gecko reset button on power up Chris64 Gecko Drives 3 02-27-2008 02:58 AM
On an OT control, hitting the reset button g-codeguy Fanuc 3 06-13-2007 11:21 PM
Help with e-stop button Astroguy Xylotex 2 05-31-2007 07:23 AM
