| Hi I just installed a 1981 yasda YPC 45 machining center. The machine is in mint condition. Anyways here comes the problem. When i fire up the machine everything seems fine. I do atc chek and table ready. I set the mode to MDI go to COMND move a page down, to start a block. I punch the desired code and press INPUT. When it is done (and here`s the pickle) i press start and nothing happens. I`ve tried everything i can think of i`ve turned the machine on and of sevral times. But sudenly this morning, when i turned the machine on it worked. I used the machine for some time and turned it of. When i some time later turned it back on again it`s same old same old. That said i have no experience with fanuc controll what so ever. So i might have got something wrong from the start. But i`ve read the user manual and can`t see that i have. Anyhow any suggestion why this could be. |
| In MDI did you enter EOB end of Block? Does the START light come on? No end of Block, no START light. If START light, then program is hung up on a command. Al.
| Sorry to say Al either i din`t get when to press EOB or it didn`t work. (The first reason is probably the best explanation.) But since i didn`t press EOB in that glorious moment it actualy worked. I suspect something else to be the reason. I do suspect a slightly defect start button. But i also suspected every other button to be defect intill i knew how to use them ![]() And you mentioned a start lamp i can`t really identify one. PS: i added some screenshots. maybe some of you who has seen how the scrren shuld look like kan identify if you see something suspicious. |
| EOB is a button and a semi-colon is entered at the end of a line before ENTER. Usually the MTB puts a light in the Cycle-Start P.B. To test the buttons you can go to the diagnostic page and look at the inputs to see if one changes from 0 to 1 when pushed. Al.
| problem starting up FANUC | gisbertz | Fanuc | 16 | 05-30-2009 03:14 PM |
| Starting in the middle of a program.Old control. | lostkoss | General CNC (Mill and Lathe) Control Software (NC) | 3 | 10-07-2008 09:11 AM |
| Need Help!- STarting NEw project - Need Serious Help to Understand PArts before starting | osix | DIY-CNC Router Table Machines | 2 | 06-30-2008 03:54 PM |
| fanuc program comments | Rich 72 | General CNC (Mill and Lathe) Control Software (NC) | 3 | 09-04-2007 07:38 AM |
| FANUC 6M Program format | Moolvie | Fanuc | 3 | 10-07-2005 09:37 PM |
