Old 10-08-2008, 11:29 AM
KTD1 is on a distinguished road
Fanuc 16M + Trig
Anyone know if the 16M control can do trig?
If so, have any examples?
I have 60 different parts that have angles that need stepped on them. Each slightly different angles in slightly different locations.
I've done this on a Bridgeport DX-32 control but that machine is busy.
Old 10-08-2008, 12:06 PM
Dan Fritz is on a distinguished road
If you have the User Macro B option, then you can do trig. Try putting this command into a program and see if it alarms out or not:
#101=SIN[1.0] ;
If you have User Macro B, the statement will save the result in macro variable #101. If it alarms out, you probably don't have the option installed.
Old 10-08-2008, 01:49 PM
#101=SIN[1.0] ;
Entered your command on MDI screen and hit cycle start.
No errors or alarms
Where could I view the macro variables to see if it took?
Old 10-08-2008, 02:00 PM
stevo1 is on a distinguished road
Press your settings key until you see the local variable page it should list 1-33. Page up and down until you reach #101 this should equal the answer to the Sin of .01745.
Stevo
Old 10-09-2008, 05:26 AM
Thumbs up Got it
Stevo
I found the screeen and it's there.
Now I need to put the brain in gear and write the program.
Thanks for the help guys.
Old 10-09-2008, 07:46 AM
your welcome. Let us know if you need help with the programs.
stevo
GE Fanuc & FANUC proprietary posts CNCadmin Fanuc 44 01-05-2012 08:54 AM
Fanuc 16M + Trig ? KTD1 Parametric Programing 3 10-15-2008 07:48 AM
Trig help 3axisrookie G-Code Programing 4 04-03-2008 10:16 PM
How to trig out I and J ? vmc4020 G-Code Programing 10 10-11-2006 08:47 AM
