Problem c axis work shift
Results 1 to 4 of 4
Thread: c axis work shift
    Oct 2007
    Default c axis work shift
    I'm using a 21I controller on a lathe with live tooling.
    We stick our z axis work shift in some of our codes (parameter #2601). I was wondering if there is a similar parameter for a c - axis work shift?
    Thanks for any help.
    Dan
    Aug 2006
    Brazil
    Dan,
    1) C-Axis is the living tool or the spindle ???
    2) Using system variable #2601 you modify only the tool geometry to shift the Z axis.
    Daniel
    Oct 2007
    Parameter number #2601 in this control is listed as a workpiece coordinate shift. In the operators manual it is listed like this:
    Workpiece coordinate system shift amount:
    x axis: #2501
    z axis #2601
    When I put a value for #2601 it is inserted into the z axis workshift.
    I'm looking for a similar parameter number for the c axis.
    Thanks,
    Dan
    Jun 2008
    In your work coordinate does it show "C"
    X axis
    Z axis
    C axis??
    If it is listed they usually go in order. Try #2701.
    Or does C show up in your woork coordinates?
    An example of your work coordinates lets say G55
    X=#5221
    Y=#5222
    Z=#5223
    C=#5224
    This will depend on how many coordinate axis you have listed.
    Stevo
c axis work shift
c axis work shift
