Old 09-26-2008, 06:53 PM
g-codeguy is on a distinguished road
Need parameter for the spindle RPM.
Is there one? I want to put the current spindle speed into a variable for use in a macro sub. This would be on OT, 18-T and 21i-T controls. I found where the orientation and maximum RPM parameters are, but didn't see anything in regards to reading the current spindle RPM. Google didn't turn up one either.
Thanks.
Old 09-28-2008, 09:37 PM
cnc-king's Avatar
cnc-king is on a distinguished road
gcode take a look at 3708 bit#3
If you can ENVISION it I can make it
Old 09-29-2008, 07:40 AM
Now I am thoroughly confused. This is my first attempt at programming a macro to read a system parameter. Old Hardinge deep drill (P9135) cycle used J to specifiy the retract position. Newer P9136 sets #4=#5002 at the begining of the subprogram, and uses that for the retract position. Looking at parameter #5002 yields this:
WNP=0 for bit 7
LWM=1 for bit 6
LGC=1 for bit 5
LGT=0 for bit 4
bit 3 & 2 =0 and have no designation over them
LGN=0 for bit 1
LD1=0 for bit zero
Yet Fanuc manual lists in the table under
*Current position Table 16.2(1) System variables for position information
Variable number- #5001-#5008
Position Information- Block end point
Coordinate system- Workpiece coordinate system
Tool compensation value- Not included
Read operation during movement- Enabled
So how does one know that #5002 reads the block end point Z-axis position? I assume that the 8 variables have a set order since the other variables listed also have 8, but what are they reading? I would guess that #5001=X, #5002=Z, #5003=Y, but have no idea for the rest.
EDIT: Solved. #4119 reads S-code. Still would like an answer on my other questions. Thanks.
Need Hardinge spindle parameter. g-codeguy Fanuc 4 05-09-2008 05:12 PM
OT parameter, spindle stops when switching, Ztiggi Fanuc 4 11-07-2007 12:50 AM
dnc parameter help shepherd Machine Problems, Solutions , Wireless DNC, serial port 1 06-27-2007 12:28 AM
Parameter changes jorgehrr G-Code Programing 9 02-15-2007 08:06 PM
How to setting fanuc serial spindle parameter? ning Fanuc 1 10-30-2005 02:38 PM
