Old 09-22-2008, 08:54 AM
joehernandez is on a distinguished road
punching a program
hi guys im new to this and im using a fanuc 15-m im trying to punch a program for the controller to my pc but having problems can anyone give me a step by step on what i need to do im using cnccom 6..20
Old 09-22-2008, 10:51 AM
stevo1 is on a distinguished road
I am not firmiliar with cnccom but I have attached a PDF that shows the wiring for RS232 connection to the CNC. I get my pc ready to transmit and on the CNC go to edit then program press overarrow keys until you see the read softkey. Press read then you have a selection for All Or program. Press ALL. the machine should receive the program set up in the PC. If you are trying to send progams 8000-8999 you must unlock them with parameter 11.0 =0. If programs 9000-9999 it is parameter 2201.0 =0.
Stevo
Old 09-22-2008, 03:39 PM
fixmycnc is on a distinguished road
15 COMM
These two files may help.
Old 09-23-2008, 09:25 AM
thank Guys
but still no luck punching out the parameter,programs,etc. the fanuc is a fanuc series 15-m
Old 09-23-2008, 09:45 AM
Joe did you get your PM??
We need more information. Is the machine giving an alarm? Is the software giving and alarm? Is the data going but in a different format? Does the CNC and PC just sit there?
Stevo
Old 09-24-2008, 06:51 AM
sorry for keeping you guys waiting
it just sit there i can send a program into the fanuc 15 m from my pc but i cant send it from the fanuc to the pc what the main problem is that i use cabinet vision and the post is set to add D9 which on mastercam it doesnt so everything i cut on cabinet Vision doesnt work unless i change that d9 to a d17 or any number that doesnt have a offset on it
(TOOL: 1/2 COMP)
(DIA: 0.496)
T9
M7
G0 G17 G90 G58 X7.4775 Y35.127 M15 S15000
M53
G43 H9 Z1.
G0 Z0.85
G1 G42 D9 X9.125 Z0.0263 F200.
X18.248 F300.
Y45.248
X0.002
Y35.127
X9.125
X9.621
G40 X11.2685 Z0.85
G0 Z1.
X26.8525 Y24.752
Z0.85
G1 G42 D9 X28.5 Z0.0263 F200.
X56.998 F300.
Old 09-24-2008, 07:39 AM
texwoodmaint is on a distinguished road
Fanuc 15M punch to pc
Try the following procedure it has worked with our fanuc 15M.
read this all before you try it.
1. set to edit mode
2. press program soft key
3. press the operation key (bottom right key under monitor) until you get the Punch soft key
4. make sure your pc is ready to receive the file and you know the name and loication
5. press punch soft key
6. press (prog#) soft key type program N0. then press EXEC soft key
7. or you can press ALL soft key to send all programs
You may have to check the communication parameters.
Try this web site [url]www.theservicegroup.us look for there technical documents.
Good Luck:>
Old 09-24-2008, 11:02 AM
the website doesnt work
Old 09-24-2008, 12:01 PM
You are correct.
The following is the procedure I used when the pc crashed and needed to change the RS-232 cable 9 pin pc(female) to 25 pin fanuc(male)
These changes are for the cable configuration I changed.So make sure you note all previous values befor changing them if this does not work you will have the original parameters.
Power up machine.
Press the left soft key to ge to the screen "SETTING SERVICE MESSAGE"
Press "SETTING" key until "SETTING(SERVICE)" appears in the upper left hand corner of the screen. Use the up arrow key to get PARAMETER #8000.
Arrow over to the right until cursor is under the bit labled "PWE".
Turn the mode switch to "MDI".
Press 1, then press "INPUT" soft key.
You will get an message on the screen.
Use the down arrow to go to PARAMETER # 0000.
Type in 00001010 and press "INPUT" soft key.
Use the up/down arrow keys to change the following parameters:
20=1
21=1
22=1
23=1
5001=3(Device type#1)
5111=1(STOP BITS)
5112=8(BAUD RATE)
5120=3(DEVICE TYPE#2)
5121=1(STOP BITS)
5122=8(BAUD RATE)
BAUD RATE VALUES
8=1200 10=4800
9=2400 11=9600
Press the "SETTING" soft key to get back to PWE bit again and change it back to 0. Hit reset to clear alarm.
Press the SETTING soft key until you get the "SETTING(HANDY)" screen
it should appear as:
TV CHECK=0
PUNCH CODE=0
INPUT UNIT=1
INPUT DEVICE=1
OUTPUT DEVICE=1
INPUT DEVICE=1-BG EDIT-
OUTPUT DEVICE=1-BG EDIT-
After you are done pwer down and reboot.
Try to punch to the PC aslo the PC must be configured to the same BAUD rate and stop bits as the fanuc.
Old 09-24-2008, 12:25 PM
Joe,
Check your handy settings. Edit mode, program soft key, over arrow, handy.
Whatever device your using 1-3 set should be the same for the output device.
The program you posted does not have a program # in front of it.
O0001
(TOOL: 1/2 COMP)
(DIA: 0.496)
T9
Do you ready your PC before sending the program from the CNC?
Stevo
Forum for Punching machines Independent CNC General Metal Working Machines 22 08-12-2011 04:22 AM
CNC Turret punching? andy_ck87028 DIY-CNC Router Table Machines 0 02-08-2008 05:53 PM
How accurate is steel punching? taws6 General Metalwork Discussion 7 05-07-2007 11:10 PM
Beginner Question - Punching Holes lostbaka General Metalwork Discussion 5 01-22-2007 11:32 PM
Punching Station for Vacuum Machine Cooper Vacuum forming, Thermoforming Etc 1 09-15-2006 09:11 AM
