Is there a parameter that can be edited for the sec/rev. time on a horizontal cnc w/ pallet change. I have a '94 model Saeilo Mach 3 Horizontal CNC with a Fanuc OM control and a turntable style pallet change. I am about 50 lbs. shy of the maximum weight limit for the tables. My problem is when I program a pallet change that there is so much momentum with the rotation that the whole turntable slams into the rubber bumpers. The book says it should be currently 10 sec/rev. I am setting the machine up for production and I don't think it would be a good thing to keep running the machine as is. I guess worst case, I set up a new fixture but with less parts to hold. I am currently holding 4 parts. 2 per tombstone. I've looked thru the books and did not find any such parameter to change this. Anybody out there have any ideas? |
| I agree with dcouper. as far as the "hunt", the cylinder cushions should be on the end caps of the cylinder. Usually a set screw with a jam nut. Its does not take much adjustment on these so make small adjustments to them. RRL |
| Need Help!- HAAS HS-1 Pallet Change problems | cweiss | Haas Mills | 3 | 07-30-2008 04:42 AM |
| pallet change program, needed | stew | Fanuc | 0 | 01-02-2008 01:45 PM |
| How in the world do you change the jog speed? | CNCadmin | Mach Mill | 3 | 01-06-2007 11:42 PM |
| Pallet Change | CNC Mendez | G-Code Programing | 6 | 07-25-2006 12:50 PM |
| Does controller change axis motor speed? | samualt | DIY-CNC Router Table Machines | 5 | 10-10-2003 04:05 PM |
