I'm something of a newbie to setting up controls and communications, so I need a little help here. Our current setup, while functional, is pretty slow. I'd like to optimize the parameters on the control and DNC Precision software to improve the data transfer between PC and CNC. We don't use drip-feed or anything exotic like that...I'm just a bit anal about efficiency
Using port 2, my current parameters are set as follows:
In the CNC, I have 2400, 7E1, using Hardware flow control.Code:5018 00000001 5019 11000101 5020 00000001 5021 11000101 5022 00010001 5023 10010011 5024 10101010 5025 00000001
If anyone can suggest what parameters to set, and what to set in the DNC, to speed up file transfers, I would greatly appreciate it.
