I am trying to write a post for a Mazak Lathe with a Fanuc 6t controller. I do not have much experiance with CNC lathes(mostly all mill). Here is the example program: % :0001 ( PLAN#9020 OP#20 ) N002 G20 N004 G50 X-50000 Z225000 N006 G00 T0101 N008 G97 S0100 M41 N010 M03 N012 G00 X12.098 Z6. N014 Z4.134 M08 N016 G50 S0175 N018 G96 S0100 N020 G99 N040 G01 X12.8086 F.006 N050 G02 X12.8666 Z4.1621 I0. K.029 N060 G01 X12.8834 Z4.434 N070 G00X12.0834 N080 X12.298 Z4.234 N090 G01 Z3.672 N100 G00 X11.498 M09 N110 Z6. N200 G97 S0100 N202 G00 X-50000 Z225000 N204 G00 T0100 N206 M01 N208 G50 X-50000 Z225000 N210 G00T0101 N212 G97S0100M41 N214 M03 N216 G00 X8.878 Z6. N218 Z.589 M08 N220G50S0175 N222G96S0100 N230G01X9.504F.006 N240G00X9.004Z.689 N250X9.078 N260G01Z-.031 N270G00X8.878M09 N280Z6. N300G97S0100 N302G00X-50000Z225000 N304G00T0100 N306M01 N308G50X-50000Z225000 N310G00T0202 N312G97S0100M41 N314M03 N316G00X11.91Z6. N318Z3.678M08 N320G50S0175 N322G96S0100 N324G01X12.8498F.004 N330X12.8194Z3.5648 N340X12.7696Z3.4478 N350X12.7052Z3.3301 N360X12.5446Z3.0832 N370X12.4828Z2.9899 N380G03X12.4048Z2.9414I-.0674K.0143 N390G01X12.3066Z2.9192 N400X12.1494Z2.6972 N410X12.0728Z2.5976 N420G03X11.6202Z2.1219I-4.0267K1.624 N430X10.5136Z1.4405I-2.57K1.5216 N440G01X10.3584Z1.3688 N450G02X9.5335Z.8261I2.0677K-1.9995 N460G01X9.4362Z.7362 N470X9.4056Z.7057 N480X9.3838Z.683 N490 G00 X8.7838 M09 N500 Z6. N600 G97 S0100 N602 G00 X-50000 Z225000 N604 G00 T0200 N606 M30 % -First off anybody have the M and G code list for this controller/lathe? -Second whats the deal with N004,N202 and so on i see that in every program and through out this one? -3, whats line N006 T0101? is that tool one? I am sure I will have more question but this is the basics. thanks |
| No list of G and M codes for the 6T here. N006 ? An "Nword is just a line number, and depending on the age of the machine, may not be required, but then it may. T0101 - Tool position 1, offset #1 Any specific questions about the codes listed in this program? |
| N004 G50 X-50000 Z225000 - zero preset command. Usually the distance from the part zero to the tool tip (when X and Z are home). Note that there's a matching G00 X-50000 Z225000 at the end of each tool. My guess is these were generic numbers that got edited (in pairs) each time the job was run. The operator would touch each tool off the OD, add the X machine position to the the diameter of the part and record that value, touch off the face, record the Z machine position, then edit the G50 and matching G00 block to the new numbers. |
| yes i have got G code list for 6T but M codes are machine manufactuers special expect some M codes like M3 (sp. cw), M4( sp. ccw), M1(op. stop), M0(op. stop w/o condition), m2(prog. stop), M30(prog. stop), m8(coolant start), m9(coolant stop) . 2. In N4 this is coordinate setting for offsets. 3. T0101 is tool no. 1 with its offset no 1 . vipan katyal |
Vipan, Is it possible to attach that here or list them here? Its a Mazak lathe if you have the M codes by chance? thanks! |
| Fanuc 6T G-codes: G00 Positioning (rapid traverse) G01 Linear interpolation G02 Circular interpolation CW G03 Circular interpolation CCW G04 Dwell G10 Offset value setting G20 Inch data input G21 Metric data input G22 Stored stroke limit ON G23 Stored stroke limit OFF G27 Reference point return check G28 Return to reference point G29 Return from reference point G30 Return to 2nd reference point G31 Skip cutting G32 Thread cutting G34 Variable lead thread cutting G36 Automatic tool compensation X G37 Automatic tool compensation Z G40 Tool nose radius compensation cancel G41 Tool nose radius compensation left G42 Tool nose radius compensation right G50 Programming of absolute zero point (G50 X---- Y---- Z----) (also used for Maximum spindle speed setting (G50 S----)G65 User macro simple caling G66 User macro modal calling G67 User macro modal call cancellation G68 Mirror image for double turrets ON G69 Mirror image for double turrets OFF G70 Finishing cycle G71 Stock removal in turning G72 Stock removal in facing G73 Pattern repeating G74 Peck drilling in Z axis G75 Grooving in X axis G76 Thread cutting cycle G90 Cutting cycle A G92 Thread cutting cycle G94 Cutting cycle B G96 Constant surface speed control G97 Constant surface speed control cancel G98 Per minute feed G99 Per revolution feed Standard EIA M-codes (your machine tool builder may not use some of these) M00 Program Stop M01 Optional (Planned) Stop M02 End of Program M03 Spindle CW M04 Spindle CCW M05 Spindle OFF M06 Tool Change M07 Coolant No. 2 ON M08 Coolant No. 1 ON M09 Coolant OFF M10 Clamp M11 Unclamp M12 Unassigned M13 Spindle CW & Coolant ON M14 Spindle CCW & Coolant ON M15 Motion + M16 Motion - M17 Unassigned M18 Unassigned M19 Oriented Spindle Stop M20-29 Permanently Unassigned M30 End of Tape M31 Interlock Bypass M32-35 Unassigned M36-39 Permanently Unassigned M40-45 Gear Changes if Used, Otherwise Unassigned M46-47 Unassigned M48 Cancel M49 M49 Bypass Override M50-89 Unassigned M90-99 Reserved for User |
| Interesting programming method. Mixed decimal and least increment (no decimal point) programming. I hate it when people do this. Some controllers force it for certain instructions though. G50 is just like G92 for a mill. Have you used G92 on mill? On a lathe you call up the tool and offset at the same time. T0101 is like T01 H01 D01 on a mill. T0100 is tool number one with no offsets. Note that they call this before returning to home. Bob
__________________ You can always spot the pioneers -- They're the ones with the arrows in their backs. |
| Thanks for all the help guys. The other programmer isnt to good and isnt willing to help so I am stuck to figure it out on my own. Let me make sure I understand this, Line N004 G50 x-50000 z225000 is the zero point of the program. This would be -5.0Inches in X and z is 22.5inches(radius??). T Then on line N202 it is rapiding back to the zero point set at line N004? Can I just use decimal instead of mixing incremental and decimal? Thanks again! |
#10
I would think so, but am not positive. Try it on the first tool. See if it works. Keep rapid feedrate down and check distance to go. Hand on feedhold. I started on old Warner & Swaseys. No decimals were allowed. Newer machines allow you to program either way. At least ours do tho I don't understand why anyone would want to. Much easier for everyone to understand with the decimal. EDIT: What does your manual say about the G50 block? |
#11
| The Fanuc 6T can take decimal point formatted numbers or "trailing zero" numbers with no decimal points. It won't matter at all. Just remember that when you are in INCH mode (G20), you must put 4 digits after the "imaginary" decimal point. When you are in METRIC mode (G21), you only put 3 digits after the imaginary decimal. 1.0000 or 1.0 or 1. or 10000 = 1 inch (in G20) 1.000 or 1.0 or 1. or 1000 = 1 mm (in G21) |
#12
| What is the point of these lines? Is it just a tool change? Dont get why he is turning off constant surface speed and then going to referance point then calling out a referance point again and turning Constant surface speed off again. Can this be simplified? N300 G97 S0100 N302 G00 X-50000 Z225000 N304 G00 T0100 N306 M01 N308 G50 X-50000 Z225000 N310 G00 T0202 N312 G97 S0100 M41 N314 M03 Last edited by mgb1974; 10-07-2008 at 10:42 AM. |
| Using GOTO in a mazak program | CAMCRASH | G-Code Programing | 8 | 03-16-2012 05:31 AM |
| Need Help!- Sample EIA program for Mazak lathe | extanker59 | Mazak, Mitsubishi, Mazatrol | 5 | 10-24-2011 08:16 PM |
| Need Help!- MAZAK Program transfer | MJMark | Mazak, Mitsubishi, Mazatrol | 3 | 08-27-2008 09:04 AM |
| Mazak M2 Sample program EIA | zabba | Mazak, Mitsubishi, Mazatrol | 13 | 05-01-2008 06:23 AM |
| LATHE G28 Help Understanding!!!! | 1ctoolfool | Haas Mills | 13 | 10-24-2007 04:34 AM |
