Results 1 to 11 of 11
Thread: Chanche tool MDI
    May 2008
    Portugal
    Chanche tool MDI
    hello,
    I have a Fanuc OM Model C.
    The program 9000 is active to tool change, if i made a program like
    T1 M06;
    M30;
    In aut works well.
    But in MDI mode i put T1»»input»»M06»»input»»start it doesn't work.
    I can't in MDI insert in same line T1 M06 (the insert in not possible)
    And always M06 is made before T1 and only change in table "M03" to M06.
    Can help me.
    Castro
    Registered dcoupar's Avatar
    Mar 2003
    Try typing the following:
    T1M6; then press the INSERT key. (; = EOB)
    May 2008
    Viet Nam
    Oh, maybe you can try M06 ( input) then T1( input) followed Start
    May 2008
    Portugal
    In MDI mode I can't put in same line T1M06, but in edit mode i cn put in the same line.
    Castro
    May 2008
    Viet Nam
    You may need to input M06 fist.
    Mar 2003
    How about T01 INSERT M06 INSERT EOB INSERT?
    May 2008
    Viet Nam
    In case of my OM machine, if I put T01 first then the machine can't run correctly, it's easy to fix if I put M06 first( maybe pushed Cycle Start) then T01, the machine runs correctly that way.
    May 2008
    Portugal
    How about T01 INSERT M06 INSERT EOB INSERT..
    The insert doesn't work in MDI, I think the problem is in parameters.
    Castro
    May 2008
    Viet Nam
    @davide.castro
    Did you have OM parameter manual? If not, pls. sent me your E-mail address, I'll sent you OM parameter manual and OM parameter, witch I wrote from normanly run machine.
    Aug 2008
    canada
    i have same problem. way i do it is like this t01 insert .(cycle start)m06 insert (cycle start) it takes time but how often you have to do it. i don't mind.
    May 2008
    Portugal
    My email is davide.castro@sapo.pt
    Castro
    1. Changing tool diameter in the tool offset screen
      By Vern Smith in forum Haas Mills
      Last Post: 09-24-2008, 10:54 AM
    2. T slot tool post with drill bit tool holder
      By brucesu1 in forum CNC Tooling
      Last Post: 06-09-2008, 06:04 AM
    3. Very slow tool change on Tool Room Mill
      By Capt Crunch in forum Haas Mills
      Last Post: 12-21-2007, 01:20 PM
    4. G43.1 - Tool Axis Direction Tool Length Compensatioin
      By EngTech in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 12-06-2007, 05:01 AM
