Old 08-27-2008, 12:17 AM
banausicjosh is on a distinguished road
M Code in Canned Cycle Question
I'm running a oi-mc in a canned drilling cycle, I would like to have the M7 (air) blow off the drill after each hole. I've kind of messed around with different things, but I can not get it to work. Any suggestions?
Thanks!
Old 08-27-2008, 08:24 AM
jamesweed's Avatar
jamesweed is on a distinguished road
can you display/edit the built in drill sub? I'm thinking not cause I believe its built in the ladder logic??? If you have macros enabled, then you could program your own custom canned drill cycle that could include a air blast after each hole.
Old 08-27-2008, 03:03 PM
g-codeguy is on a distinguished road
You've got the right guy helping you. Mr Jamesweed knows his stuff!
Newbie- G84 CANNED TAPPING CYCLE mmussack Mastercam 15 11-25-2008 10:02 AM
cant rigid tap in canned cycle,why? stovepipesteve Haas Mills 2 06-19-2008 07:15 PM
G76 Canned cycle Stebedeff Fanuc 1 02-07-2008 11:42 AM
G73 Canned cycle problem 69owb CamSoft Products 2 09-08-2007 01:49 PM
canned cycle on Haas GITRDUN G-Code Programing 6 11-22-2006 11:44 AM
