Where's the G41/G42? Also looking at the program I see 2 blocks with the same X value, different arc directions, and a Z value that is way out of wack. The X values could be correct, but I have no way of knowing that. I definitely can say the Z is way off.
EDIT: I also have to ask why do people keep using R.1 with something like U.025 or U.02 values for DOC? Doesn't make sense to me. You are wasting a lot of time cutting air. My standard value is R.01 no matter what the DOC is.
LinkBack URL
About LinkBacks
