Old 08-09-2008, 11:11 PM
Namnp2007 is on a distinguished road
Help for tool change macro on OM VMC
Hi all.
We have 04(four) VMC , with OM controler. Now we have trouble with them, because we have not any document, and all program are deleted, so we can not change the tool(pls. see attached file). Do any one have the macro( usualy named as O9001) , or have any way to change the tool.
Pls. help us.
Thanks all.
Old 08-11-2008, 07:32 AM
Stu_M3 is on a distinguished road
Fanuc OM toolchamge macro
:9020 (TOOL CHANGE MACRO)
IF[#1015 EQ1 ]GOTO50
IF[#20 EQ#0 ]GOTO60
#1100 =1
#106 =BIN[#1032 ]
IF[#106 EQ#20 ]GOTO40
#101 =#4001
#102 =#4002
#103 =#4003
G17 G91 G80 G0 M86
M19
M85
G30 Z0.
M82
M84
M07
G28 Z0.
T#20
M07
G30 Z0.
M83
M88
M81
N30 G#101 G#102 G#103
N40 M87
G90
#1100 =0
M99
N60 #3000 =1 (M06-NO-T-CODE)
G90
M99
N50 #3000 =2 (MACHINE/MST-LOCKED)
G90
M99
There may be some machine specific parameters that need to be changed as this is from a Yang Eagle machine.
Best of luck
Stu.
Old 08-11-2008, 08:05 PM
Dear Stu M3
Thanks you so much for your reply.
Old 08-12-2008, 11:18 AM
f-bu is on a distinguished road
As seen from the picture, your magazine is with fixed position pots, so a.m. macro will not do the job - for T=1..6 you should first leave the tool in his pot, then pick the new one from another place. all these coordinates were maybe in some >500 variables
Edit Tool Change Macro Oi-MC dtmtim Fanuc 4 09-21-2007 07:34 AM
O9000 Tool Change Macro omkargupta Fanuc 1 09-11-2007 04:34 PM
O9000 Tool Change Macro omkargupta Fanuc 1 09-10-2007 04:41 PM
Tool Change Macro cncdiag Mazak, Mitsubishi, Mazatrol 0 03-26-2007 02:20 PM
A sample tool change macro. gar Haas Mills 17 08-22-2005 05:13 PM
