Old 08-01-2008, 05:48 PM
darioespin is on a distinguished road
Exclamation HELP WITH VERTICAL CENTER BRIDGEPORT BPC-250V, FANUC 11M, 1986 MACHINNE
Hello, as are all?
I have a vertical center Bridgeport PCB-250V with Fanuc control 11M. dated 1986
I introduced the following judgement.
When running a program from the peripheral (lapte op) all axes are moved according to the lines read, gives me a work stoppage when the runs the G43 line of code, stopping the team without being able to resume reset, it can only continue to operate when the machine shut down completely. The display does not present any parameters of error.
The electrical connection is through a phase converter Des co-new 20 hp.
Previously implemented programmes successfully.
Old 08-04-2008, 07:35 AM
stevo1 is on a distinguished road
Can you post the code that it is stopping at so we can take a look at it? There is nothing different about the G43 line in the previous programs you say work?
Stevo
Old 08-04-2008, 06:46 PM
thanks for your advice, I make some testing jogging axes manually and the result is not problem moving X and Y axes, but when I tried to move manualy the Z axes it moves upright ut the Y always but dowm Z minus it doesnt move, Now when I use the MPG I can move the Z axes on both direction + and - any time, but when go back to auto or jogging mode the z axes only moves downright. Other test it do was use the alarm and self diagnostic software that the fanuc control have and on the display position deviation amount appear 3000 number that stay steady but the Y and Z axes blinking, changing 0 and 1 intermitentenly. What do you think it is?
Old 08-04-2008, 06:49 PM
previosly I post about four drilling programs using g43 and it works OK!
Old 08-05-2008, 10:03 PM
famoldin is on a distinguished road
Try mantenance
Hi. probably you must check the electrical contac on front control panel, and clean those push buttons and also check the motors carbons.
good Luck!
Need Help!- Fanuc 11-T CNC lathe center programcode manoharan General Metalwork Discussion 3 08-24-2008 12:33 PM
DMG Deckel Maho Vertical Center DMC 1035V CNCCS Deckel, Maho, Aciera, Abene Mills 1 07-11-2008 11:58 PM
Need Help!- CNC Vertical machining center soumen Mori lathes 0 03-11-2008 09:06 AM
ACROLOC series 10 Vertical Milling Center CNC DieGuy General Metal Working Machines 2 07-20-2005 05:12 PM
anyone knows about Mazak Vertical Center? kamran67 General Metal Working Machines 3 07-04-2005 11:55 AM
