I have a fanuc 0M-d on a hardinge vmc1000. I work exclusively with aluminium so i need high speed and feed. This controller is not desingn for high feed machining, no lookahead. I must put exact stop at each cornering to respect programmed tool path or dramatically slow down. I wonder if changing controller for a more recent could be a good option. |
| What you need to know is the limitations due all to the controller or will motor/load inertia Problems surface if a replace with a modern controller? without recalculating the motor sizing etc. Al.
Thanks, Pete |
I have a zero C on a standard 3 axis mill (Leadwell) with AC Drives, I've checked into third party stuff but it always gets down to also replacing the drives too. So at the IMTS show fanuc introduced a affordable version of the zero, as a direct replacement, the 0I-D. My Question is what is the Price range of this product????????? No more memory problems increased G-code options, Fast BUT WHAT ARE WE TALKIN ON PRICE??????????????????????????????????? |
| Where to Get ram upgrade? | A+ Machining | Fadal | 8 | 09-24-2006 08:12 AM |
| BP CNC Upgrade | contractdesign | Bridgeport and Hardinge Mills | 20 | 08-15-2006 04:08 PM |
| upgrade | bbrreid | General Metal Working Machines | 1 | 02-03-2006 03:10 PM |
| V4 to V5 upgrade | Swede | Visual Mill | 6 | 07-06-2005 06:16 PM |
| upgrade | Rudee | Fadal | 4 | 01-29-2004 09:19 AM |
