Old 07-21-2008, 09:14 AM
BobM3 is on a distinguished road
Adding 4th axis to Hardinge w/fanuc
I bought a used rotary table for my VMC and now I need to get my VMC to use it. I have a Hardinge VMC1000II with a Fanuc 0i-MB controller. The machine came prewired for a 4th axis. I've picked out a servo drive board for the servo motor (Fanuc A06B-6114-H103). Now I need to look at what else I'll need to do to get the rotary table going. Will I have to modify the ladder diagram? Change some parameters? I know I'll have to cable it and tune it.
Old 01-07-2012, 03:33 PM
cnc int is on a distinguished road
Hi bob:
Could you intall the 4 axis?
Right now, i am trying doing the same :S
I have the same servo drive, but the motor that the 4 axis have to use is alpha i motor, what did you do?
Best regards
Old 01-07-2012, 05:31 PM
gbowne1 is on a distinguished road
I have 8 different VMC's which use different FANUC controls. I would like to add a rotary 4th to them. But I want to set up 4th axes disconnect so that I could then just unplug and turn it off, the the control revert to a 3 axes machine.
Also I have to find a suitable rotary table (or have one built).
I would especially like this for the 18i and 16.
Old 01-07-2012, 11:56 PM
fordav11's Avatar
fordav11 is on a distinguished road
good luck with that! extra axis always requires extra wiring (always undocumented) and secret parameters (always undocumented)
Old 01-08-2012, 12:15 AM
That's what I figured. But whatever I do will be well documented as always.
Know of any good servo rotary tables under 13"?
Need Help!- Adding an X axis power feed to my smithy 1220XL milling table.Adding an X axis power matridium Smithy 0 05-28-2008 10:37 AM
Adding 4th axis bgmnn HURCO 2 05-23-2008 10:56 AM
adding a 4th axis? airbrush Rockcliff Machine 17 10-12-2007 05:00 PM
adding 4th&5th axis cnc prog Daewoo/Doosan 1 09-25-2006 04:26 AM
Adding A 4th Axis helix77 EdgeCam 1 04-13-2006 02:36 PM
