Results 1 to 9 of 9
Thread: backlash
    Jun 2006
    CANADA
    backlash
    Not sure if this is where this post should be but i am putting it here anyways..
    We have an older machine an Exel Mustang VMC with a Fanuc O-M controller. When i clean a round circle well...it just doesnt cut round. I assume it is backlash. Now how does one correct this..is it a controller fix or do the ball screws have so much play they need to be replaced. They dont look overly worn for a 1991 machine..
    Registered beege's Avatar
    Feb 2008
    After reading numerous posts on the subject, it could be:
    Backlash
    Thrust bearings
    Gibs loose
    Excess following error
    Poorly tuned servo motors
    Did I miss anything?
    Good luck, detective!
    Jun 2006
    CANADA
    Quote Originally Posted by beege View Post
    Backlash
    Thrust bearings
    Gibs loose
    no...i think you covered it very well...i am going to have my work cut out for me i think...
    Sep 2005
    Forgot one: Check the fit of your tool holders in the splindle taper also.
    If you have the old analog style drives (I think you do on the 0M), you may just need to ballance the following error between X and Y. There is a diagnostic that you can use to see the following error. Making a 45 degree X-Y move at a typical cutting feedrate should show the same following error in X as in Y, and the following error should be the same in each direction. Tweaking pots on the servo amplifiers can ballance them. I believe that RV2 is used on the old analog servo boards for this.
    Jun 2005
    us
    http://www.kentechinc.com/tip2.html
    This will show you how to fix it.
    Tim
    Jun 2006
    CANADA
    Quote Originally Posted by timlkallam View Post
    followed the procedure in the link worked great....but now i am having some trouble setting the parameters....enable the pwe...go to the parameters i need and try to enter the values but nothing inputs...
    Have heard so many horror stories about fanuc and wiping parameters i dont want to touch something i dont know about...shgould i be in MDI to change parameters???
    Feb 2008
    PWE setting
    in MDI, under "settings" page, set PWE = 1
    then parameter changes under "service" page
    When complete, go back to "settings" page, PWE = 0
    Some parameter changes require reboot to be effective, so, power off and on again just to make sure.
    Jun 2006
    CANADA
    still no luck...
    1. set pwe to 1
    2.bring up parameter list by pushing dia. soft key
    3.go to parameter...in this case 535
    4.parameter current value is a single 0
    5.want to enter a value of 13 so i type 13 and push input
    6. nothing happens so i enter a value of 00000013 and push input
    and again nothing happens
    7. set pwe back to zero ...hit reset and power down...
    8. power up and still no change
    I know it is just something simple...missing a step or hitting wrong button somewhere...
    Jun 2006
    CANADA
    ok...wrong button...not diagnostic button...
    scoll with cursor and page down..
    think i got a handle on it now...
    1. Replies: 8
      Last Post: 03-10-2008, 04:35 PM
    2. Backlash
      By N4NV in forum Linear and Rotary Motion
      Last Post: 03-28-2007, 09:37 PM
    3. backlash
      By mad mark in forum Fadal
      Last Post: 02-15-2007, 02:58 PM
    4. Servo idea - elimated backlash - zero backlash !
      By synthetiklone in forum Linear and Rotary Motion
      Last Post: 12-06-2006, 02:35 PM
    5. Backlash Nut !!
      By craftech in forum DIY CNC Router Table Machines
      Last Post: 12-07-2004, 12:14 AM
