Old 07-08-2008, 02:17 AM
sinha_nsit is on a distinguished road
G71 type I and type II cycles
Earlier, there was only type I cycle (I think so). Type II cycle was introduced to take care of undercuts or pockets along the length of the job. The control identifies these two cycles on the basis of whether only X is programmed in the P block, or both X and Z are programmed. Earlier, Z was not allowed in the P block (in type I cycle). My question is that, if we program both X and Z in the P block, for a job which has monotonic increase in both X and Z (i.e., has no undercuts, hence suitable for type I cycle), what will happen?
Old 07-08-2008, 08:55 AM
I don't know about any other machine but on a Haas nothing unusual happens if you have X and Z in the P block; the cycle runs fine whether it is monotonic or non-monotonic.
Old 07-08-2008, 01:37 PM
CNCRim's Avatar
nothing should working fine.
Old 07-10-2008, 04:15 AM
radius compensation in Type II G71 turning
Fanuc 0i manual says in G71 type II section:
"The offset of the tool tip radius is not added to finishing allowances. In turning, the offset of the tool tip radius is assumed to be zero."
Does it mean that radius compensation (G41/42) is not possible in type II turning?
Old 07-10-2008, 08:20 AM
On some machines tip compensation is not active during the G71 but is applied in the G70 cycle. It is necessary to make the finish allowance large enough to include the compensation amount. As far as I know this applies to both type I and II.
Old 11-03-2008, 05:34 AM
udrııl79's Avatar
udrııl79 is on a distinguished road
examples
G71 TYPE 2
O1234
G97M3S1500
T0202
G0 X71 Z1
G71 U3 R1
G71 P1 Q2 U1 W0,5 F0,25
N1 G0 X50 W0,1
G1 Z0.
X60 Z-5
Z-20
X57 Z-23 **********
Z-30 *********
N2 G1 X70
G0 X150 Z200
M30
(ATTENTION TOOL ANGLE)
What type of CNC router? edlee Want To Buy...Need help! 1 03-06-2008 11:48 AM
What type of oil to use Grego Shopmaster/Shoptask 2 12-22-2007 01:55 PM
CRC Type binzer GibbsCAM 2 07-06-2007 11:48 AM
what type of control skippy LinuxCNC (formerly EMC2) 7 10-12-2005 05:36 AM
what type of CNC do I need? Goldhunter_2 Mechanical Calculations/Engineering Design 6 06-24-2005 10:57 PM
