Results 1 to 5 of 5
Thread: Fanuc OM Help
    Mar 2004
    TALLAHASSEE FL
    Fanuc OM Help
    I have question regarding our old controller(FANUC OM)…
    We had a 101 error(Please clear memory)
    I cleared the memory and then needed to reinput the tool carousel subroutine which is a O9000 PROGRAM. The O9000 programs are write protected and when I input I am getting an 074(Illegal program number) code.
    I have also occasionally gotten an 087(buffer overflow message) that lists as the I/O unit or PCB is defective.
    Can anyone tell me the controller settings how to download the tool carousel O9000 program?
    Thanks in Advance
    Mar 2004
    TALLAHASSEE FL
    OK, This is a forehead slapper. I did this years ago with Parameter 10 as reminded in the newbie string below.
    Registered dcoupar's Avatar
    Mar 2003
    Parameter #10, bit 4 = 0 will allow editing of 9000 programs.
    Jun 2008
    To load and unload 9000 programs there is a parameter that write protects these programs. I do not have a OM control parameter manual. But you will have to set PWE parameter to 1 then change the parameter that write protects the 9000 programs. This parameter blocks loading and downloading 9000's.
    As to the buffer overflow this is a common alarm when your settings between your computer and your machine are off. The easiest thing to try is slow down your baudrate. If this does not work on your computer go to SYSTEM icon in the control panel under HARDWARE, DEVICE MANAGER, drop down the PORTS list, click the port your DNC is using, click PROPERTIES, PORT SETTINGS, ADVANCED, set the FIFO to it's lowest setting, and click ok when exiting all menus.
    Good luck!
    Mar 2004
    TALLAHASSEE FL
    Thanks for the responses.
    That helps with the buffer overflow- I was ready for a board replacement
    1. GE Fanuc & FANUC proprietary posts
      By CNCadmin in forum Fanuc
      Last Post: 03-20-2013, 10:54 AM
    2. FANUC & GE FANUC Repairs
      By RRL in forum Product and Manufacturer Announcements
      Last Post: 04-17-2011, 12:50 PM
    3. Replies: 2
      Last Post: 07-12-2007, 02:59 PM
