Old 06-19-2008, 05:46 AM
gene1157 is on a distinguished road
gene
I am using a 10t controller and am having trouble with a radius. I am coming off of a 20 degree angle and then need to put a 55 degree radius to finish the part but I get a step in the radius I am getting frustrated
Old 06-19-2008, 07:01 AM
Stu_M3 is on a distinguished road
sounds like the end points are out somewhere post your programme
Old 06-19-2008, 01:39 PM
need help
Hope you can help!
G1Z.215X.4874F.002
G2Z.195X.523R.02
G1X.605Z.155
Z.03
G3Z0.0X.545R.058F.001 this is where I have trouble
Old 06-20-2008, 02:42 AM
I presume from the prog that this is a lathe. I am not familiar with lathes but if you have a drawing of the part you are machining and also a bit more of your programme I might be able to help. ive drawn the prog up on cad but i cant see what you are trying to achieve without more info.
Gene Haas ddprecision Haas Mills 0 11-07-2007 02:04 PM
