Old 06-13-2008, 12:19 PM
PhoenixMetal is on a distinguished road
Fanuc 6M: Converting paper tape to computer file
I need to convert a paper tape into a computer file so that I can later load it via RS232 and also so I can print it out.
Due to a settings problem, I cannot do this in the normal way by loading the tape into the machine's memory and then downloading the memory to the computer via RS232.
Is there a way to run the tape reader in manual mode and dump the output directly to the RS232 port for capture on the computer?
If not, is there anyone who can convert my tape to a file for a fee?
Thank you,
PhoenixMetal
Old 06-13-2008, 05:49 PM
*Registered*
Mike Stevenson is on a distinguished road
Wow ancient history. Good luck finding someone.
Old 06-13-2008, 05:57 PM
Al_The_Man's Avatar
Some time ago, I put together a Fanuc reader and built a RS232 interface from a old USART chip, the reader is parallel data, so it has to be converted to serial for RS232.
I believe I still have it somewhere.
Is this a parameter Tape?
Old 06-16-2008, 09:38 AM
Hi Al, wow that's really great if you could dig that thing up. Yes you are correct - it is a parameter tape. If you can find the device, the please give me a price and I'm sure we can work together. Thank you!
Old 06-16-2008, 11:21 AM
Al_The_Man's Avatar
I have dug it out, later today I will make sure it still works by running a tape through.
Old 06-16-2008, 01:35 PM
neilw20's Avatar
neilw20 is on a distinguished road
Question How long is it?
If the tape is fairly short, you could hand decode it. A bit painful but doable.
I have a PTR and punch, with RS232 but I am a long way away. Sending an important irreplaceable tape is a high risk due to loss or damage.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 06-16-2008, 01:45 PM
Hi neilw20, the tape is quite long so hand-decoding would be quite tedious and error-prone. I see you are in Australia - wow,that is is quite a ways away, so perhaps sending it there is a greater risk than within the US or Canada... Thank you though!
Old 06-16-2008, 01:55 PM
neilw20's Avatar
Question
You can't get much further away than NY. ! What sort of machine is this on?
Old 06-16-2008, 02:10 PM
The tape is for a Wiedemann Centrum 1000 Turret Punch Press with a Fanuc 6M control.
Old 06-16-2008, 03:49 PM
Al_The_Man's Avatar
I have it tested, I ran a Fanuc 0 tape through that ended up at 4K+.
If you want to Pm me I can give you an address to send to.
  #11   Ban this user!
Old 06-16-2008, 03:54 PM
Dan Fritz is on a distinguished road
If this parameter tape has been loaded into the control, why not just punch out the parameters through the 6Ms serial port. To do that, display the parameter page, put the control in EDIT mode, then press "P-9999" then PUNCH. This would give you an accurate backup of the parameters that are in the CNCs memory, which may be a bit different than what's on that tape.
You can connect a Fanuc parallel tape reader directly to a PCs parallel port and read in a tape, but that would require a special cable and special software for the PC. Al_the_man's serial adapter may be a much easier solution.
  #12   Ban this user!
Old 06-16-2008, 04:25 PM
Hi Dan,
The reason I am not simply punching out the parameters that are already saved on the CNC is because Wiedemann thinks that some of the parameters have been corrupted. That is why I want a fresh load of the parameters from the original tape.
I have no problem making a custom cable, and maybe I'll have to go down that route, but first I would like to see what can be done with Al_The_Man's solution.
Contact Paper as transfer tape tauscnc Printing, Scanners, Vinyl cutting and Plotters 0 11-03-2007 05:05 PM
question about file converting cncmachiningzon Solidworks 1 04-14-2007 10:51 AM
I need to build a paper tape emulator paramax55 General Electronics Discussion 14 04-11-2007 04:40 PM
Converting a File Tazzer ArtCam Pro 0 10-30-2005 04:52 PM
Converting a .max file DAB_Design General CAM Discussion 5 01-28-2005 01:00 PM
