Results 1 to 2 of 2
Thread: Set Value for Backlash Fanuc 0M
    Apr 2008
    Indonesia
    I have a problem when adjust Backlash for X and Y axis.
    I already change the whole bearings for all 2 axis, change the ball steels of ballscrew nut but when I make a circular cutting still have a step cut every 90°. I know it must be a backlash value that I have to input into parameter 535-536.
    That I would like to know, how to find the right value to parameter above to make a smooth cutting to my product ?? when I measure with dial, indicate that there is 20 microns for X axis to move a ballscrew. I divided 20 microns with 2 (plus and minus) and added to parameter 535. Is it right that I have done???
    Sep 2006
    I believe you have to convert it to metric. Then add or subtract it to the value. Its been a while for me though
  1. Replies: 8
    Last Post: 03-10-2008, 04:35 PM
  2. BACKLASH PARAMETER FANUC 0M
    By Stebedeff in forum Fanuc
    Last Post: 01-17-2008, 12:33 PM
  3. Fanuc 5T Jumpy? /Bad Backlash
    By John3 in forum Fanuc
    Last Post: 03-18-2007, 07:59 PM
  4. Servo idea - elimated backlash - zero backlash !
    By synthetiklone in forum Linear and Rotary Motion
    Last Post: 12-06-2006, 02:35 PM
  5. Backlash?
    By mgamber in forum Gecko Drives
    Last Post: 04-25-2003, 05:12 PM
