Results 1 to 4 of 4
Thread: RS232 communication on Fanuc 21i-TB control
    Jun 2008
    We have 2 machines that use Fanuc series 21i-TB control. When we send files via rs232 to a computer, the control adds (2) line feeds inbetween each line of code. How can I stop the line feeds in the control?
    Registered dcoupar's Avatar
    Mar 2003
    You can choose what gets output at the end of block by setting parameter #100 bits 2 and 3 per the attached.
    Attached Thumbnails Attached Thumbnails RS232 communication on Fanuc 21i-TB control-crlf_output_options_-_21i.jpg
    Banned
    Jan 2006
    Seattle
    Since the dawn of NC these extra codes have plagued the user. You either had software that compensates for them or you do what dcoupar suggests and change the parameter. Well done dcoupar.
    Jun 2008
    Thanks! This is exactly what I needed.
  1. What software is necessary for RS232 Communication?
    By 61SedanMan in forum Haas Mills
    Last Post: 04-07-2008, 02:01 PM
  2. RS232 communication software
    By gar in forum Haas Mills
    Last Post: 08-13-2007, 09:56 PM
  3. Okuma OSP100E RS232 Communication Problem
    By Edster in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 03-20-2007, 07:57 PM
  4. Help! RS232 Communication to Fanuc 3T Control
    By m1_machine in forum Fanuc
    Last Post: 10-30-2006, 03:08 PM
  5. Fagor RS232 Communication - No Luck
    By cammo in forum Fagor Automation
    Last Post: 08-17-2005, 01:19 AM
