I have 440A unit from DosTek unit (http://www.dostek.com/btr440d.htm) on my 6M and it's been working well from day one. It costs about CDN$700.
Chris Kirchen
Hi guys. Once again pulling from the vast amount of knowledge on this board. Have been working on my DNC setup for 1983 Kitamura Mycenter3 and have discovered through help here that I can't drip feed this model without a Behind Tape Reader board. Suggestions for economical sources??
Thanks again, Dave
Chris Kirchen
Try a direct BTR connection from Refresh Your Memory, Inc. You run a special BTR cable from your PCs parallel printer port directly to the Fanuc mother board. No additional boards needed. PC-DNC Editor software feeds the data to the Fanuc through the BTR connection just like the paper tape reader at 300cps. Putting a PC near the machine gives you the ability to:
Edit files on the PC while running programs on the Fanuc
Run or edit files off a network drive (or wireless network)
Lets you see the program text scroll on the screen while cutting
Call files and merge them into your program like subroutines
Do a lot of advanced editing (part rotation, scaling, offsetting, etc.)
Contact John Hosmon at RYM. john@rym.com or 408-224-9167
Thanks Dan. I think I'll try that. computer is only 5 feet away. Don't think I can afford the BTR option yet. As always I value the input you've given to all here. Thanks, Dave
