Old 04-29-2008, 01:27 AM
hell_pk is on a distinguished road
Strange problem with HT 40
Hello,
we have heitachi Seiki NK 40(also called HT 40) machine.Sometimes its "offset" button on display stops working.after couple of hours it starts working again.what might be the problem?
Old 04-29-2008, 05:23 AM
system is 10T
by the way system is 10T.We have checked the entire crt system including buttons,circuitry,pcb traces for continuity,replaced cards with another Ht 40 machine but nothing helped.problem might be in NC in back cabinet.
Moreover machine has an optical interface(a 2 wire connector) going from front CRT module (which contains offset button) to back cabinet NC motherboard.How do we chect this optical interface or cable.can we use regular continuity using multimeter.
any ideas someone?
Strange problem ! BP II interact 4 bherr Bridgeport and Hardinge Mills 11 08-28-2008 09:48 AM
CNC strange problem huben_123 TurboCNC 4 03-14-2008 06:12 PM
Strange Fanuc battery problem timlkallam Fanuc 0 11-22-2007 09:58 PM
Strange G03 problem sploo Mach Mill 4 11-14-2006 05:24 PM
strange motor problem sp00k1e General Electronics Discussion 4 03-23-2004 05:46 PM
