Check parameter 10 bit #7. IIRC it should be 1 to automatically set a coordinate system when manual zero return is performed.
Also check parameters 708 (X), 709 (Y), and 710 (Z) vs. your other machine. These should be the positions that are preset when you do a manual zero return.
LinkBack URL
About LinkBacks
