Results 1 to 3 of 3
Thread: HITACHI SEIKI / Fanuc 11m
    Apr 2008
    We have 2 Hitachi Seiki Horizonal Mills with Fanuc 11m controllers.
    I have the RS-232 serial port wired like any other Fanuc 11m controller but the machine can only recieve not send back to the DNC software.
    Someone from the shop said that a repair tech plugged a tradional null modem cable into the machine and his laptop and it worked.
    I dont get it.
    What am I doing wrong.
    Any help would be greatly appreciated.
    Thanks Much
    Mike
    Apr 2008
    Fanuc 11 Serial Port Setup from Memex
    Fanuc 11s have parameters that set which port, and which protocol you will use for input and output in both foreground and background modes.
    Note that CD4 on the masterboard is I/O RS232C interface 2, and CD1 on the monitor is I/O device 1.
    Check the following:
    - Parameters 20 & 21 (foreground I/O - you want 1 or 2 for interface 1 or 2);
    - P22 & P23 for background I/O (once again 1 or 2).
    - P5001 for which I/O device number is attached to RS232C interface 1,
    - P5002 for 2 etc.
    Then check the port group (device number) you are using (if I/O device 1 then),
    - P5110 = 3 (DC codes are used and feed is not punched)
    - P5111 = 1 or 2 for stop bits
    - P5112 = Baud (10=4800, 11=9600) <- I have noticed that 4800 is the effective max throughput rate BTW
    etc..
    Then check the cable - null modems are needed with lines 6, 8 & 20 jumpered (you get a CD or 86 alarm if buy an off-the-shelf null modem cable in other words).
    Finally, check the port itself - the RS232C driver chips (75188 is the transmitting driver and 75189 is the receiver chip). Use a LED mini-tester to see if the port (TX is blown). Check our website listed below for wiring diagrams of Fanuc ports.
    Good Luck,
    Tom Gaasenbeek
    Memex Automation Inc.
    PS: We make DNC and memory upgrades for Fanuc 11s, so we know these controls well (see www.memex.ca).
    Banned yours_prabhat's Avatar
    Dec 2008
    India
    Hi all in this forum
    This is Prabhat from USHA MARTIN LIMITED deputy manager machinery Divison Ranchi India. Tis is not only a site its an institution
    prabhat
  1. Need Help!- Hitachi Seiki 4NE 600 parameter fanuc 3T-D
    By ahmedrehan in forum Fanuc
    Last Post: 11-06-2010, 05:49 PM
  2. Fanuc 6MB Problem on a Hitachi Seiki VA-50
    By bachlewelding in forum Fanuc
    Last Post: 05-04-2008, 07:21 AM
  3. Need Help!- Hitachi Seiki
    By jsp973 in forum Mori lathes
    Last Post: 04-21-2008, 02:34 PM
  4. HITACHI SEIKI 25S/FANUC 10T PROBLEMS
    By conceptmachine in forum Fanuc
    Last Post: 04-21-2008, 09:29 AM
  5. Hitachi Seiki
    By mroy0404 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-08-2007, 12:28 AM
