If this means that when your NC receives a program, it loads the program fine but the LOAD message on the screen never disappears. Then the problem is that it never receives the end of record wich generally uses the % simbol, try writing this symbol at the end of the program, also you can press RESET to erase the LOAD and all will be OK.
If the problem is diferent maybe you can explain so I can try to help you.
GP.
LinkBack URL
About LinkBacks
