Not sure what else has to change, never had to mess with it, but parameter #1006, bit #3 , if 0, radius is specified, if 1, diameter.
I think my W&S WSU 12 is set fot radius programming. I am used to diameter programming on our Tsugami with a 6T control. The WSU has a 10TF controller. Is there a parameter to change or a code to put in the program? The reason I think it is set up for Radius is that on the x register if I move the slide 1 inch it shows movement of 1 inch not 2" as it should be in diameter programming. Thanks for any help.
So change the fourth bit from the right to a one, report back... You know about PWE, yes?
Parameter number 8000 (in "settings", MDI) has a bit labeled "PWE" (protect write enable or something). That bit has to be turned on, in settings, in MDI mode. Then, in Service mode, the other parameter is changeable. You should get an alert when you first change PWE, but set it back to zero when you're done, and hit reset, all will be well. I think then you have to power down and restart to make the change effective. But don't forget (write down) what you've changed. This might give you problems, though, if other parameters were written while in radius mode.
It looks like # 1816 , bits 4,5 and 6 adjust DMR (detect multiplying ratio), but i haven't a clue as to what to chance here, and 1850 is "grid shift", which may be what GRD means.. Just looking at the book, don'tcha know.
