| I am looking to us a radius groove tool to turn an outside radius (tube groove) and I want to use Tip code number 8 to center the tool. The problem is that G41 or G42 shifts the tool to right and left, I need it to stay centered. Is there anyway to do so, maybe another G-code?? Is it possible?? Or will I have to use Double offsets and program it seperatly. Last edited by demeyert; 04-02-2008 at 04:42 AM. |
| If you're OD contouring TOWARDS the chuck, your tool needs to be offset RIGHT (G42); going AWAY from the chuck, the tool needs to be offset LEFT (G41). You can use T3, T8, T0 or T9 for this, it just depends on where you set the tip nose when you touch off the tool. The most common method of setting Geometry Offsets is to touch off the leading edge of the insert to the face of the part, and the "bottom" edge of the insert to the OD of the part (or to the Q-setter if you have one). If you do this with an OD tool, by default you've established "Imaginary Tool Nose Number" 3. Put a 3 in the T value for that tool offset, and the radius in the R. IMHO, this is the safest method, because you always know where the edges of the tool are going to be when you rapid up to or away from the part. If you want to use Imaginary Tool Nose Number 8, either move Z- 1/2 the insert width before you do your Z0 - MEASUR (if you don't have a Q-Setter) or use the INP+ to adjust the Z geometry offset after the fact. Hope this helps. |
| Thats how I went about it. I was just curious if the maching could do the entire radius in one move using cutter comp. I just roughed it manually, and finished one side of the radius to center with G42 and then repeated for the other side G41. I am interested in those images you posted though, I could not see them when I opened them. ![]() Thanks |
| I got the images. they look good. Only thing is that it seems our controllers or codes are slightly different. I am kinda new at this but my fanuc 10 t requirements for radius seem different (G3 X1.00 Z-.015 R.015 F.002).. Or is G2 Z-.0375 K-.125 proper way?? ![]() Thanks so much for you help.. |
| SV2412 Cutter Comp Question | javajesus | Sharp CNC | 5 | 02-25-2008 08:03 PM |
| CUTTER COMP FANUC 18M? | PICMAN | Fanuc | 1 | 12-07-2007 11:53 AM |
| Fanuc 16T tool nose comp question | dmcool | Fanuc | 4 | 07-23-2007 11:21 AM |
| ProtoTRAK freezing up after cutter comp error with g-code | LancoUSA | General CNC (Mill and Lathe) Control Software (NC) | 0 | 05-23-2007 09:12 PM |
| G-Code Cutter Comp Program | jcc3inc | DIY-CNC Router Table Machines | 0 | 02-27-2004 10:29 AM |
