Old 03-18-2008, 10:20 AM
jlong58 is on a distinguished road
fanuc 15m program overwrite parameter
I am running a fanuc 15m controller on a Toyoda FA550 machine. I am loading programs through the RS232 port using Gibbscam software. Each time I re-process a program in Gibbs, it assigns it the same program number, and unless I delete the program in the fanuc memory before I send the program I always get the alarm: already exists. On the other fanuc controllers that I run there is a parameter that can be set to automatically overwrite the program. I assume it is the same with this controller. Can anyone tell me what I need to reset to correct this?
Old 03-18-2008, 10:49 AM
fanuservicetech is on a distinguished road
Looks like parameter 2200 bit#1 (2nd bit from right) need to be set to 1. It will override the existing program with new one.
Old 03-18-2008, 11:16 AM
Talking
Thanks so much. I will try it when I get to work today.
Old 11-20-2008, 01:35 PM
btdmfg is on a distinguished road
Is there a similar overwrite parameter for the 180i control? I am doing the exact same thing with our machine, and I have to delete all of the subprograms every time I send a new program to the control.
Old 11-21-2008, 07:24 AM
stevo1 is on a distinguished road
It should be parameter 3201.2
Stevo
Old 12-02-2008, 10:21 AM
It worked great! Thanks!!!
Old 12-02-2008, 11:16 AM
Your welcome.
Stevo
Fanuc parameter 901 mistux Fanuc 14 12-04-2009 11:28 AM
Fanuc 0T parameter Master_CNC General CNC (Mill and Lathe) Control Software (NC) 0 11-26-2007 01:15 PM
mf m5 fanuc parameter KENNETH BROWN Fanuc 0 11-14-2007 07:30 AM
Need help with Fanuc 6MB parameter nguyenthanhthi Fanuc 5 10-21-2007 08:12 PM
Set parameter from program....? REVCAM_Bob Fanuc 25 01-26-2007 08:11 PM
