Old 03-05-2008, 08:11 AM
hoidahl's Avatar
hoidahl is on a distinguished road
Fanuc 11m won't helical interpolate
We have an old 1984 mori seiki hm-40 with a Fanuc 11m controller. The parameter is turned on 9100(bit #2) I'm using a proven program from another machine but this was run on a okk with mitsubishi m2 control. The guy from Fanuc thinks it is my program, I can't believe it is. Any help would be appreciated.
Old 03-05-2008, 10:22 AM
dcoupar's Avatar
I have an idea! Why not post a little snippit of your program?
Old 03-05-2008, 10:25 AM
hoidahl's Avatar
N160
G0G17G40G80G90
G91G28Z0.
T7
M6
T8
G54
M11
B0
M10
G0G90X4.75Y1.016S2500M3
G43Z5.H7M8
Z.1
G1Z0.F10.
G41Y.966D57
G3X4.8Y.916I.05
Y1.184Z-.045J.134
Z-.135J-.134
Z-.225J-.134
Z-.315J-.134
Z-.405J-.134
Z-.495J-.134
Z-.585J-.134
Z-.675J-.134
J-.134
X4.75Y1.134J-.05
G1G40Y1.084
G0Z1.
G91G28Z0.
G56
M11
B180
M10
G90G0X4.75Y1.016
G43Z2.H7
Z.1
G1Z0.
G41Y.966D57
G3X4.8Y.916I.05
Y1.184Z-.045J.134
Z-.135J-.134
Z-.225J-.134
Z-.315J-.134
Z-.405J-.134
Z-.495J-.134
Z-.585J-.134
Z-.675J-.134
J-.134
X4.75Y1.134J-.05
G1G40Y1.084
G0Z1.
M9
G91G28Z0.M5
M1
Old 03-05-2008, 12:32 PM
dcoupar's Avatar
The code looks ok and backplots ok. Are you getting an alarm?
Old 03-05-2008, 01:16 PM
hoidahl's Avatar
no alarm but the machine moves in on z then interpolates.
Old 03-05-2008, 02:30 PM
emdub954 is on a distinguished road
have you tryed using loops....try changing you post output to do subroutine
Old 03-06-2008, 10:51 AM
dcoupar's Avatar
Have you ever tried to do a 3-axis feed move (G01 G91 X-1. Y-1. Z-1. F20.)? I seem to remember running into an old machine with a Fanuc that was only 2-axis simultaneous... 3-axis simultaneous was an option.
Old 03-06-2008, 06:51 PM
cncwhiz is on a distinguished road
I have this problem on some of my older controls. If you have a number in cutter comp, take it out and try it.
Old 03-07-2008, 02:26 PM
BluegrassPicker is on a distinguished road
Some of the older 11m controls did not have helical interpolation available. It was not available as an option. The software has to be upgraded, and cost big $$. Our 84 and 85 MV55's will not do helical. This is how we found out that some controls were not capable.
Old 03-11-2008, 07:12 AM
hoidahl's Avatar
Ok, had some other problems with the machine (tools flying out of spindle). Tried the 3-axis simultaneous and it does work. Tried putting a b move in and moves in all 4 simultaneous. I don't have a cutter comp set. I use gibbs cam and I'm not sure how to post in loops. Any other ideas?
  #11   Ban this user!
Old 04-08-2008, 09:01 AM
tnik's Avatar
tnik is on a distinguished road
just for a test, turn off the modal letters on your post, and see if it will work with full code lines.. eg.
G03 X4.8Y1.184 Z-.045 I.05 J.134
G03 X4.8Y1.184 Z-.135 I.05 J-.134
G03 X4.8Y1.184 Z-.235 I.05 J.134
  #12   Ban this user!
Old 04-10-2008, 05:53 AM
Chris D's Avatar
Chris D is on a distinguished road
I suspect that option is not turned on for your machine - sorry, don't recall the settings for the option parameters either.
Chris
fanuc oi-m helical parameter mcash3000 General CNC (Mill and Lathe) Control Software (NC) 3 01-01-2008 07:11 AM
HELICAL INTERPOLATION in FANUC -OMC TONY252 Fanuc 3 08-22-2007 12:27 AM
HELICAL INTERPOLATION in FANUC -OMC TONY252 Fanuc 1 08-21-2007 05:06 AM
Fanuc 11M Helical Interpolation MrMagooo Fanuc 3 11-15-2006 09:58 AM
Trying to interpolate X and A axis. Konstantin G-Code Programing 7 11-08-2006 11:09 AM
