Old 03-04-2008, 02:23 AM
malasjo is on a distinguished road
Red face Fanuc OM over travel
I have a milling machine Leadwell mch-500,with Fanuc OM,this machine stop from one year the error of this machine is 911 RAM PARITY : (HIGH)
I have fixed this error and I load the Parameters, but I have the over travel error of X,Y,and Z.
I can not move the x y z axis.
I do not know if I have a missing parameters
can any one tell me witch parameters is for this alarm.
and if any one have the parameters for this machine.
your help is appreciated.
thanks
Old 03-04-2008, 08:56 AM
fanuservicetech is on a distinguished road
Have you loaded PMC parameters yet? They are located under diagnostic screen. Press DGNOS key and page down to N300. Most machines have N300 to about N500 (every 5th parameter requires to set). i.e. N300, N305, N310 ....N500. If you do not have this information, please contact your local leadwell dealer or CAMPAT Machine tool (Leadwell importer in US) at 800-450-4120.
Old 03-04-2008, 11:58 AM
GPena is on a distinguished road
MAYBE THE VALUE OF PARAMETERS 700 TO 708 IS WRONG, YOU CAN WRITE 99999999 IN THESE PARAMETERS AND TRY WORK WITH THIS, IF THE MACHINE WORKS; THEN RETURN THE ORIGINAL VALUES FOR THAT PARAMETERS. YOU CAN ALSO INHIBIT THE OVERTRAVEL TURNING THE MACHINE ON WHILE PRESSING THE [P]+[CAN] KEYS.
GP.
Old 03-05-2008, 09:26 AM
FieldService's Avatar
FieldService is on a distinguished road
OT alarm
I would try P Cancel while powering up the machine. If that does not allow you to home the machine or do any other movements, you will just have to recheck your parameters. Parameter 1815 covers your zero return positions, so other axis settings should be around there somewhere. Your FANUC manual should be able to tell you more.
Old 03-05-2008, 03:33 PM
philserveng is on a distinguished road
I agree, the most like cause is that there is no travel limit values for each axis, they need to be input correctly, also the reference point of each axis. Simply putting in 999999 and -999999 will I am sure, cause the machine to crash into the axis end positions. Using P and Can will only work if the parameters are correct.
Old 03-10-2008, 11:37 AM
dta17aug is on a distinguished road
if you get "RAM PARITY" alarm, sould chek the CMOS backup batery. If this is the problem, replace it and restore all your paraneters. If not I don't know. Is there any other alarm on the screen?
Crash parameter x over travel adamant Fanuc 15 08-21-2008 06:04 AM
Need Help!- Fanuc 0TB axis over travel sushrut General CNC (Mill and Lathe) Control Software (NC) 1 02-15-2008 04:47 PM
Have ballscrew will travel/how far? lgalla Linear and Rotary Motion 0 01-10-2007 08:39 PM
Travel To Russia moNkaD8 Australia, New Zealand Club house 3 08-16-2006 08:16 AM
Taig actual travel TMaster Taig Mills & Lathes 0 04-06-2006 06:56 PM
